Full Version: NFO Creator Music videos
Pages: 1 2
So i have given up on https://archive.codeplex.com/?p=popatopdad
Works for exactly what i need, but sadly doesn't seem to work for anything that's not English, I'm trying to create nfos for music videos in russian
Or anyway to scrape/ create nfos for music videos, audiodb/imvdb are very poor when it comes to unpopular / non-english songs.
Is there any NFO creator that will do what i want?
I just need it to make nfos for my library, all it needs to do is
>Musicvideo<
>title<
I have never seen that program before. I guess it is old as it uses XBMC instead of Kodi, but the copyright is 2018. Is it still maintained?
You don't need a program to create nfo files. Create your own.
There is a template in the link below. Copy it into your own file and fill it out...
https://kodi.wiki/view/NFO_files/Music_v...mplate_nfo
(2019-09-22, 08:22)Karellen Wrote: [ -> ]I have never seen that program before. I guess it is old as it uses XBMC instead of Kodi, but the copyright is 2018. Is it still maintained?
I know that it's not hard, but it's time consuming, i have lot's of videos.
The problem seems to be that very few of the scraper sites that Kodi uses has comprehensive (or any) listings in Russian.
A different nfo creator program will not fix that. Are you aware of that, or are you hoping a different program will find information in Russian language?
Anyway, the only music video media manager I know of is this... https://forum.kodi.tv/showthread.php?tid=129134
==Edit==
Maybe @docwra might have a suggestion
If you just want to get musicvideos into the video library, if they are mp4 you can use tagging software to add title, artist, album, track no, genre, and cover art (poster).  It might also work for mkv but I haven't tested.  You need to enable video file tag reading in the settings (default is off/no).  Mp3tag is a freeware one (despite the name it tags various file formats).
scott s.
(2019-09-24, 05:52)scott967 Wrote: [ -> ]If you just want to get musicvideos into the video library, if they are mp4 you can use tagging software to add title, artist, album, track no, genre, and cover art (poster).  It might also work for mkv but I haven't tested.  You need to enable video file tag reading in the settings (default is off/no).  Mp3tag is a freeware one (despite the name it tags various file formats).
scott s.
I just tested this as I wanted to update the wiki but couldn't get it working with a test music video with the latest nightly.
I tried adding the MP4 tags with mp3tag, enabled video tag scanning in Kodi and then scanned with Kodi but got nothing, then when pressing "I" on the video file in the file view Kodi crashes.
Debug log: https://paste.kodi.tv/wimusimasa.kodi
Currently the best (and onlyHuh) Music Video scraper is Media Companion 3...
It actually really cleans up the artwork, and info for the Artists, for Music Videos. I've started using it on my 4000+ Music Video library with great results so far.
(2019-09-24, 15:44)docwra Wrote: [ -> ]I just tested this as I wanted to update the wiki but couldn't get it working with a test music video with the latest nightly.
 Didn't see anything of concern in the log unfortunately. I will have to pull a nightly though as I was testing on 18.4.
scott s.
(2019-09-22, 07:59)zaidrockso Wrote: [ -> ]So i have given up on https://archive.codeplex.com/?p=popatopdad
>Musicvideo<
>title<
If you are on windows you can use this batch file.
(video for proof)
It'll create nfo recursively. BUT IT'll OVERWRITE EXISTING ONES
i recommend using
folder/file.ext
artistname - title/artistname - title.ext
even if it'll work if all files are in one folder.
I am just unable to split artist and title from path, so artist and title will be the same.
Best Practice will be
1. Do lib Scan
2. Run Batch File
3. Export Library (will force overwrite existing file nfo)
4. rescan library
@echo off
REM Windows Title
TITLE NFO creator Musicvideos
COLOR B
ECHO -------------------------------------------------------------------------
ECHO  Create NFO for Musicvideos, all existing will be overwritten
ECHO  Push key to Start
ECHO.
PAUSE > NUL
for /r %%a in (*.mkv *.avi *.mp4) do (
echo ^<?xml version="1.0" encoding="UTF-8" standalone="yes"?^>
echo ^<musicvideo^>
for %%b in ("%%~na") do echo ^    ^<title^>%%~b^</title^>
echo ^    ^<^!-- start test set attributes --^>
for %%b in ("%%~na") do echo ^    ^<path^>%~dp0^</path^>
for %%b in ("%%~na") do echo ^    ^<name^>%%~na^</name^>
for %%b in ("%%~na") do echo ^    ^<filenameandpath^>%%~a^</filenameandpath^>
echo ^    ^<^!-- end test https://kodi.wiki/view/NFO_files/Music_videos --^>
REM test end
echo ^    ^<rating^>^0.000000^</rating^>
echo ^    ^<userrating^>^8^</userrating^>
echo ^    ^<epbookmark^>^0.000000^</epbookmark^>
echo ^    ^<year^>^</year^>
echo ^    ^<track^>^-1^</track^>
echo ^    ^<album^>^</album^>
echo ^    ^<artist^>^</artist^>
echo ^    ^<genre^>^</genre^>
echo ^    ^<outline^>^</outline^>
echo ^    ^<plot^>^</plot^>
echo ^    ^<tagline^>^</tagline^>
echo ^    ^<thumb^>^</thumb^>
echo ^    ^<status^>^</status^>
echo ^    ^<studio^>^</studio^>
echo ^    ^<art^>
echo ^        ^<fanart^>%~dp0^%%~na^-fanart.jpg^</fanart^>
echo ^        ^<poster^>%~dp0^%%~na^-poster.jpg^</poster^>
echo ^        ^<artistthumb^>%~dp0^%%~na^-artistthumb.jpg^</artistthumb^>
echo ^        ^<banner^>%~dp0^%%~na^-banner.jpg^</banner^>
echo ^        ^<clearlogo^>%~dp0^%%~na^-clearlogo.png^</clearlogo^>
echo ^        ^<discart^>%~dp0^%%~na^-discart.png^</discart^>
echo ^        ^<landscape^>%~dp0^%%~na^-landscape.jpg^</landscape^>
echo ^    ^</art^>
echo ^</musicvideo^>
)>"%%~dpna.nfo"
ECHO.
ECHO Creatin is done
ECHO Push key to exit
ECHO.
PAUSE > NUL
(2019-09-25, 11:52)mardukL Wrote: [ -> ]
>Musicvideo<
>title<
(video for proof)
i recommend using
folder/file.ext
1. Do lib Scan
2. Run Batch File
4. rescan library
@echo off
REM Windows Title
COLOR B
ECHO.
PAUSE > NUL
echo ^<musicvideo^>
REM test end
echo ^    ^<art^>
echo ^    ^</art^>
)>"%%~dpna.nfo"
ECHO.
ECHO.
PAUSE > NUL
I think i'm about to appreciate your help so muchh! Will test it and update you, thank you!!!
>Musicvideo<
>title<
(video for proof)
i recommend using
folder/file.ext
1. Do lib Scan
2. Run Batch File
4. rescan library
@echo off
REM Windows Title
COLOR B
ECHO.
PAUSE > NUL
echo ^<musicvideo^>
REM test end
echo ^    ^<art^>
echo ^    ^</art^>
)>"%%~dpna.nfo"
ECHO.
ECHO.
PAUSE > NUL
Not working for me, mind having a look?
https://streamable.com/jbsxv
(2019-09-25, 23:27)zaidrockso Wrote: [ -> ]
>Musicvideo<
>title<
(video for proof)
i recommend using
folder/file.ext
1. Do lib Scan
2. Run Batch File
4. rescan library
@echo off
REM Windows Title
COLOR B
ECHO.
PAUSE > NUL
echo ^<musicvideo^>
REM test end
echo ^    ^<art^>
echo ^    ^</art^>
)>"%%~dpna.nfo"
ECHO.
ECHO.
PAUSE > NUL
i could't see if you press a key.
1. double click .bat
2. press 'enter' key , when 'Push key to Start' is shown
this force run operation
3. wait till finished and message
'Creatin is done' occurs and hit 'enter' again.
Does that work?
(2019-09-26, 11:08)mardukL Wrote: [ -> ]
(2019-09-25, 11:52)mardukL Wrote: [ -> ]If you are on windows you can use this batch file.
(video for proof)
i recommend using
folder/file.ext
1. Do lib Scan
2. Run Batch File
4. rescan library
@echo off
REM Windows Title
COLOR B
ECHO.
PAUSE > NUL
echo ^<musicvideo^>
REM test end
echo ^    ^<art^>
echo ^    ^</art^>
)>"%%~dpna.nfo"
ECHO.
ECHO.
PAUSE > NUL
Does that work?
That's what i did, just doesn't do anything, did another streamable
and yes i pressed enter when it asks to press a key, when i press enter it shuts down.
https://streamable.com/9ds7a
(2019-09-26, 11:32)zaidrockso Wrote: [ -> ]
(2019-09-25, 23:27)zaidrockso Wrote: [ -> ]Not working for me, mind having a look?
Does that work?
can you run it again on another path/location other than userdata folders like 'desktop'
e.g
create folder on your hdd/ssd
c:/data/musicvideofiles/
(2019-09-26, 14:09)mardukL Wrote: [ -> ]
(2019-09-26, 11:08)mardukL Wrote: [ -> ]i could't see if you press a key.
Does that work?
e.g
Tried it, no avail, Tried it on hdd on my pc 3 folders in, tried it on usb stick, tried it on another computer, no luck
Really afraid i copied it incorrectly, but i copied it like 5 times, not sure why it's not executing properly for me.
Pages: 1 2
