2019-09-23, 15:24
Hi!
I have Kodi 18.1 x64 on a Windows 10 PC and i want to import correctly my library of Movies created with TinyMediaManager (https://forum.kodi.tv/forumdisplay.php?fid=204).
I have the problem that the tag dateadded inside the NFO file is ignored during the import process. The problem is related to the date before the 1970. I show you an example.
Movie: West and Soda (https://www.imdb.com/title/tt0144681/)
My file have this date:
The NFO file is thisĀ https://paste.kodi.tv/owujupigec as you can see the dateadded tag is this:
but after the importing the result in the database is this (there are two entry because i repeat the importing)
As you can see the dateAdded field is wrong.
I don't think the syntax of the dateadded tag is wrong (there is no hour and minute field), because other movie (with date after the 1970) works perfectly.
I'm afraid that is a bug from the Windows OS...
<dateadded>1965-10-01</dateadded>
