2019-09-28, 01:24
I have a home network including a PC on which I store all my recorded TV and Movies. I share the folders on this PC with the other PCs in the house that are used to view the videos. I also have a library database using MySQL set up on this PC to coordinate the other PCs used to watch TV. All this has been working for several years without a hitch.
Along comes a Firestick TV 4K on which I installed Kodi following the instructions on Troypoint.com. Kodi starts up and all the normal settings work but I can't access the media files on my PC.
I connected the Firestick to my home network.
The folders on the PC containing the videos are shared with advanced sharing and full access is granted to everyone.
I tried to add the files using Windows SMB. The folders that are accessible to my other PCs are //srv/RecordedTV, //srv/Movies, etc.
I try adding these folders along with the account info for the PC including the password
I am told that there is an error and the folders cannot be reached.
I must be missing a setting. The only thing I can think of is that each of the PCs has a user account that matches the one on the central PC while the firestick does not.
Any help would be appreciated.
The next question will be about using the library database. I access this library from the other PCs by editing the advanced setting.xml file and entering the Host IP address for the library. How does the firestick access this database?
