Full Version: "Play Using" feature missing from Menu when selecting a video file
I have Kodi 18.4 installed on an Android 7 TV box.  I was trying to select a different video player than the default one and I noticed that the "Play Using" feature is missing from the sub menu you get when you hit the menu key when selecting a video file to play.  I also tried using the playercorefactory.xml feature but that gave a timeout error when I installed a new file to replace the old one.  So has the Play Using feature disappeared in Kodi 18?  Or is there an alternative to allow changing the video player to something like VLC.  I have been having too many issues with the default video player with speeding up/slowing down of video while playing.  VLC seems to work fine when I just manually use it to play files outside of KODI.  Thanks in advance.
