2019-09-30, 12:08
2019-09-30, 12:47
JSON, not Jason
It's the communication interface API between Kodi and external apps. See the wiki for more details - JSON-RPC_API (wiki)
Which addon are you having problems with?
2019-10-01, 08:03
(2019-09-30, 12:47)DarrenHill Wrote: [ -> ]JSON, not Jasonin my log file it's an error: no json file couled be detected and ect.
how can i fix it ,if at all?
2019-10-01, 09:28
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
2.Restart Kodi
2021-10-23, 03:52
(2019-09-30, 12:08)gidigo Wrote: [ -> ]hi,
english is my seconed language.
what is a json object?
in my log i see it as an error that don't allowd my to open an addon
