I'm trying to build kodi for wayland on a raspberry 4 running Manjaro Linux.
While the build for X11 was rather easy, this one ends in some crude error messages.
git clone git://github.com/xbmc/xbmc.git kodi-wayland
cd $HOME/kodi-wayland
sudo make -C tools/depends/target/crossguid PREFIX=/usr/local
sudo make -C tools/depends/target/flatbuffers PREFIX=/usr/local
sudo make -C tools/depends/target/libfmt PREFIX=/usr/local
sudo make -C tools/depends/target/wayland-protocols PREFIX=/usr/local
sudo make -C tools/depends/target/waylandpp PREFIX=/usr/local
cd $HOME/kodi-build
cmake ../kodi-wayland -DCMAKE_INSTALL_PREFIX=/usr/local -DCORE_PLATFORM_NAME=wayland -DWAYLAND_RENDER_SYSTEM=gl -DENABLE_INTERNAL_FSTRCMP=1
cmake --build . -- VERBOSE=1 -j$(getconf _NPROCESSORS_ONLN)
First error is:
/usr/bin/ld.gold: error: cannot find -lpthreads
CMakeFiles/cmTC_03fdb.dir/CheckFunctionExists.c.o:CheckFunctionExists.c:function main: error: undefined reference to 'pthread_create'
when re-running the build, another error (probably a subsequent one) comes up:
No rule exists for the target "/protocols/presentation-time.xml",
needed to create from "wayland-extra-protocols.hpp"
I'm somewhat confused ... somewhere I read pthreads (note the tailing "s") was not available on Linux
(2019-09-30, 13:03)klaeuser Wrote: [ -> ]First error is:
This is not an error, its part of the tests cmake does in order to find threads, its expected on linux.
Provide full output of cmake via pastebin site.
(2019-09-30, 13:55)asavah Wrote: [ -> ] (2019-09-30, 13:03)klaeuser Wrote: [ -> ]First error is:
CMakeOutput.log
https://paste.kodi.tv/ejabixalot
CMakeError.log
https://paste.kodi.tv/wigisosohi
Hmm I can't see what fails in the console output.
Try building with one job (not parallel), so it stops right where it fails.
cmake --build . -- VERBOSE=1 -j1
(2019-10-01, 13:34)asavah Wrote: [ -> ]Hmm I can't see what fails in the console output.
ok, new attempt.
CMakeOutput.log:
https://paste.kodi.tv/epasasopup
CMakeError.log:
https://paste.kodi.tv/kivuxajuzu
and the console output:
https://paste.kodi.tv/aqowijibun
Unfortunately, this does not look much more informative either.
Hopefully I catched the whole console output!
I'm redirecting stdout and stderr to a file with tee -a logfile 2>&1, but (especially at the end of the logfile there are often some lines missing). It looks like they were written to another channel ...
I pasted the missing lines at the end of the console log - just to be complete... and hopefully I forgot nothing
I suppose there's something wrong with that file:
~/kodi-build/CMakeFiles/generate-wayland-extra-protocols.dir/build.make
58
59 wayland-extra-protocols.hpp: /usr/local/bin/wayland-scanner++
60 wayland-extra-protocols.hpp: /protocols/presentation-time.xml
61 wayland-extra-protocols.hpp: /protocols/xdg-shell.xml
62 wayland-extra-protocols.hpp: //usr/share/wayland-protocols/unstable/xdg-shell/xdg-shell-unstable-v6.xml
63 wayland-extra-protocols.hpp: //usr/share/wayland-protocols/unstable/idle-inhibit/idle-inhibit-unstable-v1.xml
I'm completely new to cmake, but the directory /protocols does not exist.
You can find presentation-time.xml and xdg-shell.xml in these directories:
find ~ -name presentation-time.xml
./kodi-wayland/tools/depends/target/waylandpp/native/protocols/presentation-time.xml
./kodi-wayland/tools/depends/target/wayland-protocols/native/stable/presentation-time/presentation-time.xml
find ~ -name xdg-shell.xml
./kodi-wayland/tools/depends/target/waylandpp/native/protocols/xdg-shell.xml
./kodi-wayland/tools/depends/target/wayland-protocols/native/stable/xdg-shell/xdg-shell.xml
looks like the prefix was missing ... for what reason ever
this might be the problem (or one of the problems):
./kodi-wayland/cmake/scripts/linux/ExtraTargets.cmake (20):
set(PROTOCOL_XMLS "${WAYLANDPP_PROTOCOLS_DIR}/presentation-time.xml"
"${WAYLANDPP_PROTOCOLS_DIR}/xdg-shell.xml" "${WAYLAND_PROTOCOLS_DIR}/unstable/xdg-shell/xdg-shell-unstable-v6.xml" "${WAYLAND_PROTOCOLS_DIR}/unstable/idle-inhibit/idle-inhibit-unstable-v1.xml")
WAYLANDPP_PROTOCOLS_DIR is set here
~/kodi-wayland/cmake/modules/FindWaylandpp.cmake (34):
# Promote to cache variables so all code can access it set(WAYLANDPP_PROTOCOLS_DIR "${PC_WAYLANDPP_PKGDATADIR}/protocols" CACHE INTERNAL "")
obviously PC_WAYLANDPP_PKGDATADIR is not set and therefore WAYLANDPP_PROTOCOLS_DIR equals to "/protocols"
PC_WAYLANDPP_PKGDATADIR is filled in the same file (line 15), but only if PC_WAYLANDPP-FOUND is set
if(PC_WAYLANDPP_FOUND)
pkg_get_variable(PC_WAYLANDPP_PKGDATADIR wayland-client++ pkgdatadir)
endif()
Obviously PC_WAYLANDPP_FOUND is not set or this pkg_get_variable function does not return a correct value.
At the moment I have no idea where PC_WAYLANDPP_FOUND comes from. It was nice to have a possibility to dump all these variables ...
somehow I'm talking to myself ...
Found a very useful cmake function called variable_watch() - this is exactly what I need!
Added two lines at the top of CMakeLists.txt:
variable_watch(WAYLANDPP_PROTOCOLS_DIR) variable_watch(PC_WAYLANDPP_PKGDATADIR)
... and that gives us some very interresting information:
/usr/share/cmake-3.15/Modules/FindPkgConfig.cmake(728): set(PC_WAYLANDPP_PKGDATADIR
PARENT_SCOPE )
Called from: [5] /usr/share/cmake-3.15/Modules/FindPkgConfig.cmake
[4] /home/klaus/kodiwayland/cmake/modules/FindWaylandpp.cmake
[3] /home/klaus/kodi-wayland/cmake/scripts/common/Macros.cmake
[2] /home/klaus/kodi-wayland/cmake/scripts/common/Macros.cmake
[1] /home/klaus/kodi-wayland/CMakeLists.txt
CMake Debug Log at /usr/share/cmake-3.15/Modules/FindPkgConfig.cmake:728 (set): Variable "PC_WAYLANDPP_PKGDATADIR" was accessed using MODIFIED_ACCESS with value "".
Call Stack (most recent call first): cmake/modules/FindWaylandpp.cmake:16 (pkg_get_variable) cmake/scripts/common/Macros.cmake:364 (find_package)
cmake/scripts/common/Macros.cmake:380 (find_package_with_ver) CMakeLists.txt:167 (core_require_dep)
OMG!
After days of debugging I finally found the problem.
An OS package (waylandpp) is missing.
The solution is quite simple:
pacman -S local/waylandpp
that's it!
Surely - Manjaro (and ARCH) Linux are not the most popular distributions, but similar things could happen on Debian/Ubuntu/Fedora/SuSe ... too.
This Check-Script (cmake/modules/FindWaylandpp.cmake) should urgently be improved!
From the error messages you can not necessarily recognize what's going on.
The script does not give any hint that waylandpp is not available, but simply sets some variables (especially PC_WAYLANDPP_PKGDATADIR) to "" (empty string) - which in turn causes WAYLANDPP_PROTOCOLS_DIR to be set to a completely absurd value - which in turn leads to the error message:
I'm not good enough with cmake to write a better check, but apparently these calls to pkg_check_modules are not sufficient to ensure waylandpp is available:
pkg_check_modules(PC_WAYLANDPP wayland-client++ wayland-egl++ wayland-cursor++ QUIET)
pkg_check_modules(PC_WAYLANDPP_SCANNER wayland-scanner++ QUIET)
