Full Version: TIDAL2 Addon not working
TIDAL2 Kodi Addon does not work properly.
When tryong to play Tidal-music, I got an error  "Tidal2 error 401, user does not have a valid session".
Tidal Android app works without problems.
See log file:
2019-09-30 19:00:10.670 T:140012100253440   ERROR: [TIDAL2] tidalapi: https://api.tidal.com/v1/tracks/11414430...tryCode=AT
2019-09-30 19:00:10.673 T:140012100253440   ERROR: [TIDAL2] tidalapi: User does not have a valid session
2019-09-30 19:00:10.673 T:140012100253440   ERROR: Traceback (most recent call last):
2019-09-30 19:00:10.673 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/addon.py", line 803, in <module>
2019-09-30 19:00:10.674 T:1400122019100253440   ERROR:     plugin.run(argv=newargv)
2019-09-30 19:00:10.674 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/script.module.routing/lib/routing.py", line 130, in run
2019-09-30 19:00:10.677 T:140012100253440   ERROR:     self._dispatch(self.path)
2019-09-30 19:00:10.677 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/script.module.routing/lib/routing.py", line 141, in _dispatch
2019-09-30 19:00:10.678 T:140012100253440   ERROR:     view_func(**kwargs)
2019-09-30 19:00:10.678 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/addon.py", line 737, in play_track
2019-09-30 19:00:10.678 T:140012100253440   ERROR:     media_url = session.get_media_url(track_id, album_id=album_id)
2019-09-30 19:00:10.678 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/resources/lib/koditidal2.py", line 270, in get_media_url
2019-09-30 19:00:10.679 T:140012100253440   ERROR:     media = self.get_track_url(track_id, quality=soundQuality, cut_id=cut_id)
2019-09-30 19:00:10.679 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/resources/lib/koditidal.py", line 1166, in get_track_url
2019-09-30 19:00:10.681 T:140012100253440   ERROR:     media = Session.get_track_url(self, track_id, quality=soundQuality, cut_id=cut_id)
2019-09-30 19:00:10.682 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/resources/lib/tidalapi/__init__.py", line 443, in get_track_url
2019-09-30 19:00:10.683 T:140012100253440   ERROR:     return self._map_request(url,  params=params, ret='track_url')
2019-09-30 19:00:10.683 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/resources/lib/tidalapi/__init__.py", line 367, in _map_request
2019-09-30 19:00:10.683 T:140012100253440   ERROR:     r = self.request(method, url, params=params, data=data, headers=headers)
2019-09-30 19:00:10.683 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/plugin.audio.tidal2/resources/lib/tidalapi/__init__.py", line 165, in request
2019-09-30 19:00:10.683 T:140012100253440   ERROR:     r.raise_for_status()
2019-09-30 19:00:10.683 T:140012100253440   ERROR:   File "/home/walter/.kodi/addons/script.module.requests/lib/requests/models.py", line 940, in raise_for_status
2019-09-30 19:00:10.684 T:140012100253440   ERROR:     raise HTTPError(http_error_msg, response=self)
2019-09-30 19:00:10.684 T:140012100253440   ERROR: HTTPError: 401 Client Error: Unauthorized for url: https://api.tidal.com/v1/tracks/11414430...tryCode=AT
2019-09-30 19:00:10.845 T:140013636555520   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.tidal2/play_track/114144302/114144297]
2019-09-30 19:00:12.679 T:140012392195840   ERROR: [TIDAL2] tidalapi: https://api.tidal.com/v1/tracks/11414433...tryCode=AT
2019-09-30 19:00:12.680 T:140012392195840   ERROR: [TIDAL2] tidalapi: User does not have a valid session
Hi @arneson
I kindly ask you to help
thx wolde
(2019-09-30, 21:24)wolde Wrote: [ -> ]Hi @arneson
thx wolde
Hello wolde,
please try to log out and log in again to get a new session ID.
Do you use the latest Version V2.0.0-beta19 ?
Look here: https://forum.kodi.tv/showthread.php?tid...pid2885173
Arneson
(2019-10-01, 22:27)arneson Wrote: [ -> ]please try to log out and log in again to get a new session ID.
Hello Arneson,
I'm still using V2.0.0-beta19
I did follow your suggestion, logged out and logged in again.
Works well now
Thank you very much for assistance.
Enjoy todays Tuesday
wolde
Hi there!
This question is a long shot, and I'm not sure if this add-on is still developed.
But do you have any information if the new Tidal Connect function will be implemented in this TIDAL add-on, or any other?
With this, it could completely replace my Librespot connect setup.
Hello Arneson,
I have a question related to the format of the URL's you are using from Tidal. They appear to be in Apple Lossless MP4 format at 44.1khz, 16bit. This means that if I request an MQA album, I am getting 44.1khz, 16bit (lossless?) instead of the lossy MQA 48khz, 24bit. There are obviously a number of streams available for any given music file.
Do you use this MP4 stream because you feel it's preferable to the lossy MQA stream?
Thanks in advance
geoff
(2020-12-03, 12:10)geofstro Wrote: [ -> ]Hello Arneson,
Thanks in advance
geoff
Hi geoff,
if a stream is marked as "Master Audio" by TIDAL, the lossless playback stream contains the MQA decoding informations to "unfold" the audio information with a capable DAC decoder.
If the stream is not marked as "Master Audio" the playback stream contains no MQA decoding informations at all.
The TIDAL2 addon requests a "LOSSLESS" playpack stream URL in both cases.
In most cases every MQA track and album is also available as a "Non MQA" version. If you play those streams you will get a 16 bit lossless audio stream.
arneson
(2020-12-03, 14:11)arneson Wrote: [ -> ]
Thanks in advance
geoff
Hi geoff,
arneson
Thanks. I'm still a little confused though, because I requested to play the MQA track. On all other systems and apps, when I do this I get a 48khz/24bit file, which is in flac format. Strictly speaking this file is lossy, unless the first unfold is performed in software (Roon, Aurdirvana, Tidal Desktop; etc.) or it is sent to a DAC with an MQA decoder, as you said. After the first unfold is performed in software, the second unfold may be performed by an MQA Renderer.
I realise that in most cases the MQA tracks are also available in non-MQA versions; but it was the MQA version I requested for play in Tidal 2
