2019-10-07, 18:03
2019-10-07, 18:34
There must be a way zebh. The options for adding a widget to a home screen are numerous almost overwhelming. I never tried to do this, focusing instead on adding interface to my Trakt account. I would just start at the first option after adding a widget. Trial and error. Maybe someone else has done this and can give the 8 or 9 steps you need 😄
2019-10-19, 09:33
You could create a playlist using source folder as a rule and point the menu item to it. I believe you need to sync the videos to your library though, so you probably need to create nfo-files for them.
2019-10-19, 15:08
odbe
ADD PATH
FILES
MANUALLY EDIT
DEIVE:\my_family_movies
plugin.library.node.editorXML:<?xml version='1.0' encoding='UTF-8'?>
<node type="folder">
<label>my family movies</label>
<path>D:\my_family_movies/</path>
</node>
ADD PATH
FILES
MANUALLY EDIT
