Full Version: S W A N (alpha , updated December-2021)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
(2021-03-20, 15:15)mardukL Wrote: [ -> ]
(2021-03-20, 14:42)doriezz123 Wrote: [ -> ]Hi mardukL,
Thanks for the great skin, I really like it!
I have a question, how do I get that in the movie/tv shows titles instead of the purple simple text Ill get movie/tv shows logos?
Sorry for the noob question
Thanks again Smile
unsure if i get you right.
clearlogo will be shown if exist, if not it'll show the title.(spotlight home, view58, view502)
there is no option to deactivate this behaviour, and it'll not come in future.
Sorry for not being clear, see the difference between the pics:
https://ibb.co/6myrbrw
https://ibb.co/8DZr8md
(2021-03-20, 16:00)doriezz123 Wrote: [ -> ]
Thanks again Smile
Ok.
for scraped files look here
https://kodi.wiki/view/Movie_artwork
if an addon provided such art it'll also shown.
if artork doesnt exist, it'll show text label of the title.
(2021-03-20, 18:49)mardukL Wrote: [ -> ]
(2021-03-20, 15:15)mardukL Wrote: [ -> ]unsure if i get you right.
Ok.
Problem solved! Thanks a lot.. very much appreciated.
when do u think you will have have another update for swan
(2021-03-21, 00:15)kow1234 Wrote: [ -> ]when do u think you will have have another update for swan
No idea, currently i try to improve/change the musichub layout and try to add some functions.
As that is a bit complicated (integrate custom sortorder,sortby - and gain right item focus after apply it will cost me a lot of time, even if it'll be for no effort if i faill)
Beside that i try to improve some things there (font,widget size, infos, smaller menu, optional currently playing bar...and more, optional layout if click on artist)
When I press the "download subtitle" while watching a movie, using Opensubtitles addon it shows the list of srts with only the word "Greek" in it and not the full subtitle path and as a result its like this : Greek
Greek
Greek
......... etc
(2021-03-22, 01:18)Slobontan Wrote: [ -> ]When I press the "download subtitle" while watching a movie, using Opensubtitles addon it shows the list of srts with only the word "Greek" in it and not the full subtitle path and as a result its like this : Greek
Greek
Greek
......... etc
Should be fixed now.
Pushed littlwe update today...
If its not working, pls report back
Pushed Update Today
Changelog 1.06~alpha (22.03.2021)
- minor code cleanup/changes
- added / adjusted dialogsubtitles , dialogslider
- added setting to disable youtube lookups for trailers for view58
- changed (wrong used) textures used in dialogkeyboard
- changed (wrong used) font dialogkeyboard
- fixed/adjusted/add settings (colorpicker, weather , embuary info )
- fixed videopreview window overlay if trailer playing in dialogvideoinfo
- fixed false operating/aplience of widget layout if setting for widget tag is changed in widget editor -> added automatic reload skin (correct theme apply ,correct size apply)
- fixed stuff in view58
    - clearlogo/label fetch
    - content calls
    - plural ; singular labels
    - refresh local trailer, if going to other show by using similiar items
    - artwork dissue ( item edges round vs default)
    - WIP unfinished choose custom focus item/page (onload focus first 'nextup widget item/page' or 'season items' ; default 'start at info')
- added functional options for autoplay trailers for dedicated viewtypes (50,56,502)
Latest update is broken. Failed to install on Leia (update) and Matrix (clean install).
(2021-03-22, 13:06)Zeule Wrote: [ -> ]Latest update is broken. Failed to install on Leia (update) and Matrix (clean install).
i'll take a look.got a bit time left.
EDIT:
@Zeule  and others.
(2021-03-22, 13:25)mardukL Wrote: [ -> ]
EDIT:
@Zeule  and others.
All good.  Rofl
great work Smile
Is there or is there going to be a netflix type view while in the movies and tv shows section?
It looks like there is from the pics in the first thread but maybe those are just the home page?
thanks
(2021-03-22, 15:11)Grumpyman Wrote: [ -> ]great work Smile
thanks
it is on to my to list.
no eta.
(2021-03-22, 15:31)mardukL Wrote: [ -> ]
thanks
no eta.
great ...thanks Smile
I know is a lot of work but, are you planning in adding artwork support for addon widgets? Like Titan MOD had. A customizable spotlight, I'd like to have, instead of stars or thumbs rating, an IMDb and TMDB ratings there. Hope some will be added.
Cheers
