Full Version: S W A N (alpha , updated January-2022)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
(2021-09-09, 11:39)mardukL Wrote: [ -> ]Maybe some Info Viewtype(s) coming soon
Info Panel - when Using Blurred Fanart
Info Panel - Not using Blurred Art
Info Panel - disabled Artwork
Info Panel - Trailer Playback
Looks beautiful , its for the main menu only? please for the movies section too Big Grin
(2021-09-12, 16:03)mardukL Wrote: [ -> ]I dont understand the question about content infos for posters ?¿....you can toggle the info setting for each widgets no matter which artwork type...
Apologies, if you look at the screenshots from first page in the thread, screenshots 21-22 show beneath the selected widget, Genre, Year, Rating, Runtime and plot.
I'm trying to work out how to display that information for widgets.
(2021-09-13, 00:15)djdirty60 Wrote: [ -> ]@mardukL
Hi, Is it possible that the player's appearance will be the same as Netflix?
No, i dont plan such osd.
(2021-09-13, 05:02)ofory2012 Wrote: [ -> ]
It's not for the home window it's for the common library views.And more for items which benefit for showing plot/itemdescription
movies | sets | tvshows | seasons | musicvideos |
artists | albums |
images |
games)
(2021-09-13, 07:35)Kokonutcreme Wrote: [ -> ]
Ah.ok.
just go the attribute settings of the wished widget and enable
the setting
"Show widget info at bottom .."
( it is where you can also set the artwork type, limit etc)
(2021-09-13, 11:51)mardukL Wrote: [ -> ][quote="djdirty60" pid='3059935' dateline='1631484944']
@mardukL
Unfortunate
(2021-09-13, 11:51)mardukL Wrote: [ -> ]just go the attribute settings of the wished widget and enable
the setting
Running 1.14 Alpha and I don't see that option "Show widget info at bottom" in widget attribute settings
(2021-09-13, 15:38)Kokonutcreme Wrote: [ -> ]
the setting
Hm..its definetly working (its in for a while, even it has some other bug )
https://streamable.com/ey5al2
BUT BE SURE YOU USE WIDGETS ONLY HOME LAYOUT
as it does'nt makes sense if using spotlight layout .
(2021-09-13, 16:00)mardukL Wrote: [ -> ]BUT BE SURE YOU USE WIDGETS ONLY HOME LAYOUT
Aaahh thank you, that was it.
Can we configure submenus in this skin?
(2021-09-14, 17:56)jdig4240 Wrote: [ -> ]Can we configure submenus in this skin?
Currently not.
It just has a experimental setting , when using
mainmenu tiles layout you are able to enable 'auto submenu'.
By enable it for menu entrys you have a submenu based on the folderpath related entrys, which are fade in and gain focus when select a menu tile.
But its currently more a placeholder for a submenu function.
Video example
No ETA when i improve | add custom submenu.
(2021-09-15, 10:10)mardukL Wrote: [ -> ]
Currently not.
Video example
Ok, thank you. I can workaround this by setting up Superfavourite folders and using your method above can effectively have submenus this way.
Still not fully done, but seems i come to an end here
testing custom colors n blurr for the "info panels"
watch gallery
great job!
(2021-09-15, 20:35)Aaiemron Wrote: [ -> ]great job!
Thanks alot Smile
@mardukL
Just discovered video OSD function where pressing down will activate bookmarks Big Grin
Don't know how I didn't notice this before, but this is a killer feature for me as one of the few annoyances with using KODI compared to other media center apps on Apple TV is the poor accessibility to select chapters/bookmarks.  If I had one request, it would be to increase the size of the thumbs but that's a minor quibble.
Many thanks.
(2021-09-19, 05:07)Kokonutcreme Wrote: [ -> ]@mardukL
Many thanks.
Thanks ;-)
Added it last update.
For the size, i'll stay this size.
but i had issues using andvancedsetting.xml for override the cached thumbs for bookmarks.
this is how it should look.
