2021-11-12, 14:28
(2021-11-12, 10:03)fantasticn Wrote: [ -> ]I also experienced the black screen issue on all my five Android TV machines. I never had that issue when I updated the skin before using the Github version. However, I then deleted the guisettings.xml so I could access Kodi again via Estuary skin. Then I reloaded the skin via MardukL's Repo, and after that manually updated to Github version by "cleaning" it first as decribed under post #545. That seemed to work at least on four of my five machines. With one machines (also running Android TV) I have a strange issue: While the others did show me version "19.1.17-alpha" when updating through the repo this maschine only gives me version "19.1.16-alpha" (using the same Repo-version 1.05). When I then try to manually update with the most recent Github version I receive the black screen issue - even if I clean that version before the update as outlined under post #545. So on that machine it seems I am currently stuck with version 19.1.16-alpha. Any ideas?The 'black screen issue' is strange, currently idk why that happens (could'nt see it at any time)
Btw.: Some feedback as to the latest changes:
- As to the new PVR support I feel the TV Guide would need a bigger font size and more color and contrast.
- The "round edges" of the background is a nice gadget. But it would be great to have an option to enable/disable that look. Also: If you select the "round edges" theme in interface section the round edges are not consistantly used in all view types and not in the main menu (MenuTiles layout). So you end up having a mixed system of round and square tiles. I am not so much a fan of the round edges. However, the respective theme should then offer a consistant use of round edges for all tiles and views throughout the skin.
- Deactivating the unused viewtypes is a matter of performance of the skin. So I would recommend doing this. However, it's a little bit tricky because you only can do it in the submenu of the viewtypes. Also you need to do it seperately for Movies/Series, Music and Pictures sections. It would be easier to do it like in Titan skin mod and have a general viewtype activation/deactivation option in the skin settings.
- Still hoping for the option to have custom entries in the shutdown menue ;-)
Anyway, I still have to point out that for me it is currently the best skin available for Kodi. While most of the recent skins play around with tons of widgets (which I feel makes the start and the usage of Kodi quite slow and complex) I love the cleaness and simplicity given by teh MenuTiles layout - especially since I use Kodi as the general launcher on my AndroidTV machines. I think it is the animation of the turning tiles combinded with the nice changing backgrounds that adds to that stylish feeling. Also I love the design of the viewtypes and the customization options. So keep up the good work and many thanks for sharing it with us!
For the update problem itself, try to update the repo within kodi and check for updates again.
(i mean go to addons - install from repo - nav to my repo - go into repositorys - update 'marduks kodi repository' )
I will double check my repo files soon if i can found any mistake there...
Quote:- The "round edges" of the background is a nice gadget. But it would be great to have an option to enable/disable that look. Also: If you select the "round edges" theme in interface section the round edges are notthanks for response, currently you can get rid of it when navigate to custom colors -> set color to 'none' or set '00ffffff' on the special : window_frame_color
Quote:It would be easier to do it like in Titan skin mod and have a general viewtype activation/deactivation option in the skin settings.It is there ;-)
- skinsettings -> library section -> on top you find a button called 'OPEN VIEWTYPE MANAGEMENT' !! (It need still improvements tough ;-) )
Quote:As to the new PVR support ...I do some adjustemnst for the guide anyway and your completely right about the font size, so i will se how much larger they will be... ;-)
The label 'test' will represen a label wich is shown when 'is new item' is 'finale episode' or is a 'live stream'
Alos there will be 3 horizontal layouts
2 line
3 line
4 line
The colors in generel can be completly user defined !
vertical layout is still untouched.
I had still to go over alot stuff related to the grid, but when done i push update..
