Full Version: S W A N (alpha , updated April-2022)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
(2021-11-27, 12:07)Aaiemron Wrote: [ -> ]
(2021-10-24, 11:03)Aaiemron Wrote: [ -> ]Is it possible to add fanart as layout in the widget attributes setting?
That's because the nextup widget uses thumbs
Goodmorning.
Did you maybe find time to think about this question?
Maybe it's an option to add episode thums as a widget layout?
So that in that case Landscape would be the real Landscape picture and Episode thumbs for people who prefer that.
Or just add fanart as a widget layout?
no progress.
nearly no time, just provide a hotfix version right now
- re add missing icons for menucontrol
- playmedia offset for playlists (skin script) which is a fix for leia version
(2021-12-07, 17:13)mardukL Wrote: [ -> ]no progress.
nearly no time
​No problem. I am already very satisfied with what you have made so far. And there is more to life than skinning of course.
Thank you very much for your hard work and knowledge.it was a pleasure following the work. Cheers!! and Kudos!!!!
(2021-12-08, 04:14)kobyboy Wrote: [ -> ]Thank you very much for your hard work and knowledge.it was a pleasure following the work. Cheers!! and Kudos!!!!
Thanks;-)
(2021-02-23, 10:53)Daviddew Wrote: [ -> ]Would you consider adding an option to search for Movies and Shows through TMDB Helper?
Is there a chance that will see a feature like this?
(2021-12-14, 18:38)ViewAfterReview Wrote: [ -> ]
Chance is high, as it is on to do, but no time frame.
I am currently working on a contextmenu addon / and helper script (later) for circumstance some missing core functions for music stuff (especially for the music hub)
playlist container related
   - switch playlistitem (move up/down)
   - delete playlistitem
library item related
    - queue item to last | next playlistposition  (artist,album,song,genre items)
    - play all songs by artist
        if either media window and on '. all albums' listitem entry,
        or if not media window for artist or album items (clears playlist, and start plaing folder)
other
   - play next song
   - play previous song
   - activate playlist window - if playlist filled
   - activate playercontrols dialog
   - save currently active playlist ( .m3u )
wip video -> https://streamable.com/98bq91
Pushed update: *.1.23
Changelog:
    - fix select action for playlistitems (fix false used offset for play title)
    - add settings to toggle default select action for music items (Music HUB related)
        • Add Song to next Position in Playlist (instead add and play = default) - previously : cleared playlist and start 'playfromhere'
        • Add Album to next Position in Playlist (instead add and play = default) - previously : cleared playlist and play album
        • Add Songs of Genre to next Position in Playlist (instead add and play all songs of genre = default) - previously : no action
    - create context menu addon , used as dependencie (WIP)
                            if either media window and on '* all albums' listitem entry,
                            or if not media window (e.g. Music HUB) for artist or album items (clears current playlist, and start playing folder)
                    other action in own menu
                       - play next song
Video - new select actions behaviour, new contextmenu addon
Simply WOW so Creative man. Awsome work.
(2021-12-18, 17:29)kobyboy Wrote: [ -> ]Simply WOW so Creative man. Awsome work.
Thanks a lot.
This new funtion(s) was long outstandig and finally found the solution.
Blush
I have a tvbox with android and I have the same error as the screen below.
Imagehttps://drive.google.com/file/d/19aTLgbi...sp=sharing
(2021-12-30, 02:25)juniors.paulo Wrote: [ -> ]I have a tvbox with android and I have the same error as the screen below.
I dont get the issue.
what did you expect in the 'subtitle' dialog ?
- i just saw that you lookup for subs via 'opensubtlitles' addon
- it founds results and show them right side
which looks ok to me.
Sorry for my poor english
On this screen below, the details of the subtitle appear. In your skin (previous image) appears only the name of the language without details, there is no way to choose without knowing which one it matches. I'm using kodi on an android tvbox.
https://photos.app.goo.gl/VqNd6SXZNza9zkK98
Thanks for the skin - it's great!
I'm wondering if you could help me with a little issue i'm having though.
When using the 'Spotlight Season Info' view, the next-up pop-up (end of episode) fails to load the next episode.
It shows correctly visually, showing the name of the show, name of the next episode etc.. but then it says that it is unable to find the next episode and returns back to the season view.
When playing from other views such as 'list', this does not happen.
Thanks in advance.
Great work on the skin, I really like it.
I have a minor nitpick though, is it possible to autohide the home menu bar (or even permanently, I only have one item and only use its widget) when using the spotlight layout?
(2021-12-31, 03:24)juniors.paulo Wrote: [ -> ]Sorry for my poor english
i' take look soon how it is possible to achieve such infos.
(2022-01-06, 05:50)jake93evans Wrote: [ -> ]Hi,
Thanks in advance.
i need to investigate it, and if found it gets fixed next update.
(2022-01-06, 18:09)gzpr Wrote: [ -> ]Great work on the skin, I really like it.
If thats the case ( no home menu entrys needed)
than just 'remove' any home menu entry via skinsettings.
( just navigate to skinsettings-> home menu items-> and click 'delete' button for each entry.
you have to shutdown via s key .
