Pushed Update:
Changelog
- changes:
• dialog subtiltes:
○ show sub filename
○ wider range for text/container
• videoplayer - osd
○ added button for 'frameadvance' function ( right beside 'playpause', if player paused )
○ playlist , show next episodes list when hit playlist button ( leia fix )
• videoplayer - videofullscreeninfo , videobookmarks/currentplaylist
○ show progressbar and current time/position
- added:
• still watching dialog:
○ a skin dialog which pop up when player is paused and 10 mins idle time
○ if no input follows in 30 secs after it is visible a user defined action will be performed
• osd
○ show current time/position, when progress(seek) slider focused
• dialog seekbar: (added)
○ by default use big labels
• skinsettings - PLAYER Section
○ ENABLE 'show video info (plot,progressbar)' when pausing , previously it was the default behaviour , its just optional now and disabled by default
○ add skinsetting: use seek gadget on bottom (smaller), instead of big info centered
○ add skinsetting: disable any seek info when OSD is active
○ add skinsetting: disable seek info, just show current position when osd slider has focusd, else show progressbar when videoinfo panel is visible
○ add skinsetting stillwatching_defaction : choose action which should be performed when you miss to hit some key in the still watching dialog
