(2022-01-22, 19:34)pdr096 Wrote: [ -> ]hi,
First of all beautiful skin really nice. I'm having performance problems with the swan skin in kodi 19.1 When I play library or addon stuff it stutters all the time. In kodi 18 there's no problem at all.
There is also no problem at all when I use another skin (titan bingie, cosmic, auramod) in Kodi 19.1 works perfectly
So really strange. My system is Mac osx Montery.
grts.
Can you post a debug log ?
Need to take a look there too.
again,updates...
*.1.28 leia changes:
• refactor code to circumstance leia "issue" - Player.DisplayAfterSeek is 'True' if playback is paused, which was fixed in > v.19.*?
*.1.27 misc changes:
• add translations [de],[nl] for seekbarinfo
• reorder seek skinsettigs settings and adjust labels
• fix condition for seekinfo ( preventing panel|player info panel show up correctly )
*.1.26 HOTfix :
• still watching dialog: idle time from 1 sec to 10 minutes, SORRY
(2022-01-23, 13:43)pdr096 Wrote: [ -> ]https://paste.kodi.tv/ahubenikum
ref:
First i have to say the suppport relating to the log is zero, because there are a few banned addons 'involved' on your kodi installation which are
a: generally not supported [
https://kodi.wiki/view/Forum%20rules ,
https://kodi.wiki/view/Official:Forum_ru...acy_Policy]
and b: can be a cause for the issue.
So , get rid of the 'banned stuff' ( didt check all addons in the log ,they are colored 'red colored' in the log you posted . better would be a clean install and than test again (as they can install dependencies which install addons with another dependencies , which generel can be risky for your system and cannot be easyly tracked down ).
Hallo again,
first of all thanks for the reply
I did what you told me. I installed new kodi clean install. I played file with confluence skin no problem when i play the same file with swan skin it stutters.
The problem only appears in kodi 19 not in 18
Here's my log
https://paste.kodi.tv/onucorayiw
grts
Hallo
I noticed when I'm playing the file in confluence skin it shows FPS : 59 fps and in your skin FPS : 8.9 fps. I suppose framerates but I don't know.
Thanks for your time anyway.
grts
(2022-01-24, 20:37)pdr096 Wrote: [ -> ]Hallo again,
Here's my log https://paste.kodi.tv/onucorayiw
grts
Thanks, i took a quick look ( not at home)
at first look the video playback itself looks fine, i assume it could be
the busyloader ( - ffmpeg related issue as .apng is used when player caching )
- till i take a deeper look
you can disable the busy loader :
go to settings -> skinsettings -> player section , on the right side 'video' category you 'll find a setting "disable busy loader in osd" and toggle it 'on'
may give feedback if that fix the issue.
and in addition, as i cannot test.
you can edit dialogbusy.xml
to this
<window>
<!-- busydialog WINDOW_DIALOG_BUSY 10138 DialogBusy.xml
ID Type Description
10 progress Progress bar
test disable bnusy via include usage
<onload condition="!string.isempty(window(home).property(busyspinner))">SetProperty(busyspinner_2ndload,2,home)</onload>
<onunload condition="string.isempty(window(home).property(busyspinner)) + !string.isempty(window(home).property(busyspinner_2ndload))">ClearProperty(busyspinner_2ndload,home)</onunload>
<onunload condition="!string.isempty(window(home).property(busyspinner))">ClearProperty(busyspinner,home)</onunload>
<controls>
<control type="group">
<visible>string.isempty(window(home).property(busyspinner)) + string.isempty(window(home).property(busyspinner_2ndload))</visible>
<!-- play act busy close - load activate busy 2nd time yt <visible>string.isempty(window(home).property(TrailerIsPlaying))</visible> -->
<control type="image">
<texture colordiffuse="$VAR[color_global_dialog_background]">colors/white60.png</texture>
</control>
</control>
<include condition="[!string.isempty(window(home).property(busyspinner)) | !string.isempty(window(home).property(busyspinner_2ndload))] + !Skin.HasSetting(spotlight_home_fanart_left)" content="busyspinner_spotlight_autoplaytrailer">
<param name="centerleft" value="70%" />
<param name="centertop" value="30%" />
</include>
<include condition="[!string.isempty(window(home).property(busyspinner)) | !string.isempty(window(home).property(busyspinner_2ndload))] + Skin.HasSetting(spotlight_home_fanart_left)" content="busyspinner_spotlight_autoplaytrailer">
<param name="centerleft" value="30%" />
</include>
</controls>
</window>
Hallo,
Thanks a lot for taking your time. I did the test with busy loader but nothing changes.
What I've noticed when I play the file with osd player info it stutters when I play the file with overlay info it seems to be normal
I put down a link with screenshots so you can see. I will try to edit dialogbusy.xml this evening.
link :
https://imgur.com/a/ifNLFkE
grts
Hallo,
Sorry to bother you so much
In the mean time I did edit the dialogbusy still stuttering.
I did a fresh clean kodi 18.9 install and your skin plays perfectly. So the problem appears in 19 only
https://imgur.com/a/oRTDRwg
thx in advance
There is an issue with unicode titles.
Hopefully not a dumb question as I have only just discovered this great skin.When I press down on the remote while watching a film or tv show up pops the plot which is great but is there a way to change the colour of the text to something more readable ( to me anyway) like white or yellow?
(2022-01-26, 18:29)ViewAfterReview Wrote: [ -> ]There is an issue with unicode titles.
ah, i check for another font set which supports that and add it...
