(2022-01-26, 20:51)hostile17 Wrote: [ -> ]Hopefully not a dumb question as I have only just discovered this great skin.When I press down on the remote while watching a film or tv show up pops the plot which is great but is there a way to change the colour of the text to something more readable ( to me anyway) like white or yellow?
No question is a dumb question ;-)
Custom Colors can be set -
it just is on another place ( still a bit unstructered terms settings )
https://streamable.com/yq9rji
the custom containers (e.g. cast) container itself is not affected ( thats on to do on to do..)
(2022-01-26, 21:12)mardukL Wrote: [ -> ] (2022-01-26, 20:51)hostile17 Wrote: [ -> ]Hopefully not a dumb question as I have only just discovered this great skin.When I press down on the remote while watching a film or tv show up pops the plot which is great but is there a way to change the colour of the text to something more readable ( to me anyway) like white or yellow?
Thanks I will give it a try later.
Thanks for that mardukL that worked great.Sorry but another question.I don't know the correct terminology so do not know what to look for.
I would like a solid colour ,probably black throughout the screens rather than the glow or glare that I have now.
they don't work when typing in Greek e.g. Γειά σου
(2022-01-27, 17:47)ViewAfterReview Wrote: [ -> ]they don't work when typing in Greek e.g. Γειά σου
got it.
i will rework font anyway,
next update will have a font set to choose...
roboto should work
https://fonts.google.com/specimen/Roboto
Thank you so much! I would like to contribute by creating a Greek translation, if you are ok with this!
(2022-01-28, 11:48)ViewAfterReview Wrote: [ -> ]Thank you so much! I would like to contribute by creating a Greek translation, if you are ok with this!
Sure, but be aware a lot of labels arent available for string.po atm... ;-)
Hallo,
I did the test with the new update and everything is working perfect now (no stutter at all)
Thanks for taking your time for testing this issue on mac osx. I really appreciate this.
I'm glad the problem is solved now so I can use this beautiful skin.
Good luck with all your future upates and projects.
grts
pdr096
Are you still planning to make watched indicators and indicators to see how many episodes a TV show has?
Thank you
Pushed update v.*.1.30:
hotfix for missing labels (which include other progress)
• fixed missing labels, due to font refactor
• videofullscreeninfo :
- dyn conatainer items : disable bg panel - respect theme
• new Viewtype 520 (Spotlight Info Panel)
early WIP, currently no restrictions
