2022-01-29, 18:35
Is the update to do with the fact that every time i select a film or tv show I am face with page full of yellow stripes across the screen?
(2022-01-29, 19:00)hostile17 Wrote: [ -> ]Sorry disregard my previous post.When selecting a film or tv show instead of seeing a page of streams there is a black page with one yellow band across the screen.I can move the band down and it appears there is a link underneath it but nothing is seen.It looks like black text on a black screen.
(2022-01-29, 20:05)jogo2908 Wrote: [ -> ]First of all, what a wonderful and awesome skin this is !
Since the new update, labels in settings were fixed, but in the display of (link)sources (scraping results) of certain add-ons, the text still isn't visible or displayed. You can only see the codec or resolution of the link.
I guess it has to do with the adaptation of the fonts.
Many, many thanks for all your work!
(2022-01-29, 20:45)mardukL Wrote: [ -> ]This sounds like the exact problem I have.(2022-01-29, 20:05)jogo2908 Wrote: [ -> ]First of all, what a wonderful and awesome skin this is !
i take a look soon.
i batch renamed font related tags, seems indeed not all fixed.
thx for report!
xml:
<F6>Skin.ToggleSetting(SwanDebug)</F6>
<F7>Skin.ToggleDebug()</F7>
(2022-01-30, 15:04)Fevid Wrote: [ -> ]I guess i know what they are talking about. it happens in some addons (not going to mention which but ones with so called "fancy" source select). Just replaced the new font xml with the previous version and fixed it, so that's where the problem lies, the previous font xml had more lines so must be some of those but I'm no expert on coding neither is something that is affecting me.
(2022-01-30, 15:28)mardukL Wrote: [ -> ](2022-01-30, 15:04)Fevid Wrote: [ -> ]I guess i know what they are talking about. it happens in some addons (not going to mention which but ones with so called "fancy" source select). Just replaced the new font xml with the previous version and fixed it, so that's where the problem lies, the previous font xml had more lines so must be some of those but I'm no expert on coding neither is something that is affecting me.
Yepp, but i need to now which window.
if it is a plugin/addon defined window it need to be resolved there.
as it most likely use an font defined by estuary ( e.g. font10 ) in its window.
but so what, i take a look to merge fonts
for compability from estuary
as can interfere with any custom plugin defined window xml which uses such fonts ( as they supposed to work with estuary )
__________________________________________
EDIT:
PUSHED UPDATE
• fonts :
- compability for addon provided dialogs/windows which supposed to support just kodi default skin (estuary)
• new Viewtype 520
- cast when trailer added - WIP, expect bugs n layout changes
now
fixed
(2022-01-30, 21:57)jogo2908 Wrote: [ -> ]Everything displaying well, after the update.
Thanks a lot for all your work and this amazing skin !
(2022-01-30, 20:03)Fevid Wrote: [ -> ]Thanks a lot for the kind words, never thought i took me so long ( especially when i am still at alpha stage)(2022-01-30, 15:28)mardukL Wrote: [ -> ]..
This new viewtype fits great with youtube channels subscription thank you!
This skin is looking really great, I'm using for quite a ling time now and seeing it grow and how stands now has been amazing, well done sir!!!
Something I always add to the swan_menucontrol is the ability to reload skin and reboot to android options from the power menu as I'm using it on a Coreelec build on a sd card and from time to time i boot on android to play openlara.
One thing I don't know how to add but that I think would be beneficial for some like me would be a coreelec access from the settings menu as you have now for prime/disney+/embuary/tmdb etc.
(2022-01-30, 22:07)mardukL Wrote: [ -> ]You're welcome, even in alpha it's more complete than most and i use it everyday(2022-01-30, 21:57)jogo2908 Wrote: [ -> ]Everything displaying well, after the update.
Thanks, glad it working as expected now.
reload skin is already available within the menu control panel when it is slided out.
For reboot, i am not sure, but i think its not possible on android os.
Or what you mean by reboot to options ?
(2022-01-30, 23:38)Fevid Wrote: [ -> ](2022-01-30, 22:07)mardukL Wrote: [ -> ]You're welcome, even in alpha it's more complete than most and i use it everyday(2022-01-30, 21:57)jogo2908 Wrote: [ -> ]Everything displaying well, after the update.
(2022-01-30, 20:03)Fevid Wrote: [ -> ]This new viewtype fits great with youtube channels subscription thank you!Thanks a lot for the kind words, never thought i took me so long ( especially when i am still at alpha stage)
I know it's on the menu control i just added myself to power menu for ease of use as i'm used to click the power menu for shortcuts.
The other option i added to the power menu was reboot to android, the box will reboot to android system instead of the coreelec/libreelec, basically a [System.ExecWait("/usr/sbin/rebootfromnand")]
