Full Version: Influence Leia
Influence is back  :-)
here the repository ,
https://github.com/ipefix-kodi/skin.influence
click "clone or download"to get the zip file
Interesting skin. Just having a first browse thankyou.
Couple of things I have found.
Added a couple of my library folders ( moves and shows) , with the "set categories as widgets option either enabled or not, I cant get any categories to show below movies and tv shows icons when they are highlighted ? either list list or widget. there are no movies or tv show widgets either ( although I dont know if this skin supports widgets given that I haven't seen it before. Library is populated , my content is there when I press on menu item on home screen. No "settings" category either.
Also no exit icon /option.
Hi, new release for the skin with power / manage / search buttons on the home screen
Available here
(2020-02-18, 14:36)ipefix Wrote: [ -> ]Hi, new release for the skin with power / manage / search buttons on the home screen
Available here
Excellent thanks.
Hi, new release for the skin with a new player video
Available here
Hello with your permission I would also like this skin and. Include your repo in mine if it's ok for you.
I cant work out how to set up "category widgets" for movies and tv shows?  My content is scraped into the library and I can access it and play it when choosing movies or shows from main menu , category icons show under "videos" and 'addons" , but I cant seem to figure out how to "edit" categories successfully to show widget rows under movies and tv shows ? Obviously I am not editing the node settings correctly ?
Looking at your pic in post 3 , the lillehammer poster , suggests to me that widgets can be set up ?
