Full Version: Cannot record anything either with timer or while watching tv
Hello,
I'm using the following:
Rasp Pi 3+
Tv headend 4.4.18.1
Libre elec 9.0.2/Kodi 18.2.
Every time I try to record something with the timer one minute before the recording is due to start I will get a pop up saying "Timer deleted tvheadend htsp client" and the recording fails. Doesn't make any difference which channel or programme and neither can I record on demand, no errors.
Before I delve into the logs is there something simpler I should check?
Thanks in advance.
Roxolanna
Can you play live TV? What sort of TV tuner do you have?
