2019-10-14, 20:11
I've created a new radio button on my PVR sideblade to switch the EPG genre colours On/Off using the following:-
The button itself works fine, but I'm trying to figure out what I need to do in order that when the genre colours are switched off, the label next to button then reads 'Genre Colours OFF'. I'm sure I've created a similar button showing both labels in the past , but rather annoyingly I just can't remember what I did.
Any guidance/feedback would much appreciated.
Cheers
xml:<control type="radiobutton" id="6062">
<include>MediaMenuItemsCommon</include>
<label>Genre Colours ON</label>
<selected>!Skin.HasSetting(disable_PVRGenres)</selected>
<onclick>Skin.ToggleSetting(disable_PVRGenres)</onclick>
<visible>Window.IsActive(MyPVRGuide.xml)</visible>
</control>
Cheers
