Here:
http://mirrors.kodi.tv/test-builds/andro...64-v8a.apk try this with the Shield plugged to the TV as you had it before. Note: This build is not suggested for everyone having the Shield connected to the AVR directly, it's simply not needed and it has no additional value.
Edit: Wait 20 minutes, the mirror needs to sync
(2020-01-01, 23:21)DaMacFunkin Wrote: [ -> ] (2020-01-01, 19:11)J3FFmaster Wrote: [ -> ]Does anybody have a definitive settings guide on how to get Dolby Atmos working in Kodi's video player on the Shield TV Pro?
I have an LG TV + Soundbar and when using Netflix via the Shield it's perfectly fine, but when watching movies through Kodi I can't get a Dolby Atmos signal through to the Soundbar.
Any ideas?
I couldn’t get Kodi to output Atmos to my LG C9 even the TV supports Atmos on the Shield from Plex, Netflix etc, as soon as I plugged the Shield into my Denon Kodi started outputting Atmos, I think maybe Kodi doesn’t output Atmos unless your TV / Soundbar edid reports TrueHD compatible.
I don't have any problems with Kodi and Atmos (lossy or lossless) on a Shield 2019 attached directly to an LG C9 (playing local content).
(2020-01-04, 03:53)averylinden Wrote: [ -> ] (2020-01-01, 23:21)DaMacFunkin Wrote: [ -> ] (2020-01-01, 19:11)J3FFmaster Wrote: [ -> ]Does anybody have a definitive settings guide on how to get Dolby Atmos working in Kodi's video player on the Shield TV Pro?
Any ideas?
Hi, so if connected directly to the C9 and you play a movie from Kodi with TrueHD Atmos, The Dolby Atmos banner displays on the TV screen?
(2020-01-04, 09:56)DaMacFunkin Wrote: [ -> ] (2020-01-04, 03:53)averylinden Wrote: [ -> ] (2020-01-01, 23:21)DaMacFunkin Wrote: [ -> ]I couldn’t get Kodi to output Atmos to my LG C9 even the TV supports Atmos on the Shield from Plex, Netflix etc, as soon as I plugged the Shield into my Denon Kodi started outputting Atmos, I think maybe Kodi doesn’t output Atmos unless your TV / Soundbar edid reports TrueHD compatible.
That's not what he said. Never the less with the build above chances are high you get it working.
Yes, I have a couple of UHD disc rips that I made. I get the HDR and Atmos banner when they play. I haven't done anything special to the config except allow passthrough of the audio formats that the C9 supports. Happy to provide any other info needed. Here is an example of one of the files.
Audio #1
Format : TrueHD
Format profile : TrueHD+Atmos / TrueHD
Codec ID : A_TRUEHD
Duration : 1 h 55 min
Bit rate mode : Variable
Bit rate : 4 062 kb/s
Maximum bit rate : 7 278 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.26 GiB (8%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
What AVR do you have connected to it? Wondering if this is properly working eARC
(2020-01-04, 18:06)fritsch Wrote: [ -> ]What AVR do you have connected to it? Wondering if this is properly working eARC
No AVR, direct connect to TV. Trying to figure out how to get kodi logs off the Shield. This is the first one I've owned.
edit: debug log below
debug log playing atmos file
Quote:2020-01-04 09:49:50.595 T:7920 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 192000 format: AE_FMT_S16LE (AE) method: IEC (PT) stream-type: STREAM_TYPE_TRUEHD min_buffer_size: 196864 m_frames: 6152 m_frameSize: 16 channels: 8
2020-01-04 09:49:50.606 T:7920 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
2020-01-04 09:49:50.606 T:7920 DEBUG: Output Device : android
2020-01-04 09:49:50.606 T:7920 DEBUG: Sample Rate : 192000
2020-01-04 09:49:50.606 T:7920 DEBUG: Sample Format : AE_FMT_S16NE
2020-01-04 09:49:50.606 T:7920 DEBUG: Channel Count : 8
2020-01-04 09:49:50.606 T:7920 DEBUG: Channel Layout: FL, FR, FC, LFE, BL, BR, SL, SR
2020-01-04 09:49:50.606 T:7920 DEBUG: Frames : 6152
2020-01-04 09:49:50.606 T:7920 DEBUG: Frame Size : 16
2020-01-04 09:49:50.612 T:7919 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
Nice :-) seems to work. You got a link to the Manual of the device?
(2020-01-03, 17:35)fritsch Wrote: [ -> ]Here: http://mirrors.kodi.tv/test-builds/andro...64-v8a.apk try this with the Shield plugged to the TV as you had it before. Note: This build is not suggested for everyone having the Shield connected to the AVR directly, it's simply not needed and it has no additional value.
Hi Fritsch,
This build fixed my issues everything is works okay now.
Will this fix be included in the next release of Kodi ?
No. It has sever disadvantages as lined out. It is not a fix - but a workaround for your specific configuration & setup.
Confused on the settings for the shield and how to get passthrough working properly , i followed the guide on how to set up the shield for lossless audio
read that "sync playback to dislpay" needs to be checked but wHen i haveit checked i dont get the lossless audio but if i uncheck it i do , this is the same on a 2017 and 2019 shield and a denon 3500.
i am sure its another setting that i messed up.
Any ideas what else i need to check?...I always check with saving private ryan and when its checked i get DSurround and unchecked i get DTS MA
thanks
(2020-01-04, 20:26)dr88dr88 Wrote: [ -> ] (2020-01-03, 17:35)fritsch Wrote: [ -> ]Here: http://mirrors.kodi.tv/test-builds/andro...64-v8a.apk try this with the Shield plugged to the TV as you had it before. Note: This build is not suggested for everyone having the Shield connected to the AVR directly, it's simply not needed and it has no additional value.
Hi Fritsch,
See:
https://github.com/xbmc/xbmc/pull/17133 - though, this for sure won't be anything for Leia
(2019-12-17, 20:51)dwalme Wrote: [ -> ] (2019-12-17, 18:58)peak3d Wrote: [ -> ] (2019-12-13, 13:10)UTAVATU Wrote: [ -> ]There is a chance, that HDR will work in YouTube
HDR YouTube is already working with the VP9 profiles. You have to enable VP9 HDR profiles in plugin.video.youtube settings.
Nvidia has already said they cannot do VP9 Profile 2 decoding which is required for YouTube HDR.
Keep in mind many videos with HDR in the title are not actually HDR (which is why they play correctly).
Iirc vp9 hdr profile 2 is working using the gles ffmpeg path, but if so, most likely only kodi 19
(2020-01-05, 01:30)Grumpyman Wrote: [ -> ]Confused on the settings for the shield and how to get passthrough working properly , i followed the guide on how to set up the shield for lossless audio
thanks
'Sync Playback to Display' will always decode and output as PCM (or Dolby Digital/AC3 if transcode enabled) because it has to do resampling (which you can't do in the compressed domain) to keep audio synced at 'off speed' display rates (This option is there, for example, to allow 23.976 to be played back at 24.000 without dropped or repeated frames, but in doing so the audio has to change speed slightly - or vary) You don't get bitstream/passthrough (and thus DTS HD or Dolby True HD bitstream/passthrough output) with this option enabled.
Beware of confusing sync playback with adjust playback refresh rate (which will switch between output refresh rates based on content - rather than outputting at a fixed rate.) My understanding is that you may need your playback to output at the original refresh rate for some HD Audio bitstreaming solutions to work properly, so enabling this on Start/Stop is required. (I do it on all platforms I have, or whitelist to achieve the same result, as I always want output refresh rates that match, or are 2:2 of the original, to avoid frame drop/repeat judder such as 3:2 on 24p played at 60Hz, 10Hz judder on 50Hz content played at 60Hz, micro stutter etc.)
(2020-01-06, 11:38)noggin Wrote: [ -> ] (2020-01-05, 01:30)Grumpyman Wrote: [ -> ]Confused on the settings for the shield and how to get passthrough working properly , i followed the guide on how to set up the shield for lossless audio
thanks
thanks for the detailed explanation
