2019-10-20, 01:37
Hi! Is there a way that, when creating the movie NFO and images, their respective names be the name of the movie file plus the extension?
I need this particular syntax because I'm using .strm files from Google Drive addon. Since the addon creates the files with the extension added to the filename, the extension is required to make resume points work, otherwise the filenames won't match in Kodi and the progress is reset when loading. I then move the files created by TMM into the local folder where I export the strm files. Something like:
Cloud folder with video file:
Joker (2019).mkv
Joker (2019).mkv.nfo
Local folder with exported strm file:
Joker (2019).mkv.strm
Joker (2019).mkv
