2019-10-20, 13:08
2019-10-20, 13:31
Basically you can't. They are intentionally kept seperate by necessity from metadata scraping.
But you can have the sections side by side on the main menu, and depending on the skin used also with widgets and other on-screen displays of items like newly added, in progress and suchlike.
2019-10-20, 16:02
not easy but with a bit of modding
monie widget
anoyherway is to use nodes abd tv in Category
monie widget
xml:<include content="WidgetListPoster" condition="Library.HasContent(movies)">
<param name="content_path" value="videodb://movies/"/>
<param name="widget_header" value="$LOCALIZE[31010]"/>
<param name="widget_target" value="videos"/>
<param name="list_id" value="5100"/>
</include>
Includes_Home.xml target="$PARAM[widget_target]" limit="15" limit="1000"xml:
<include content="WidgetListPoster" condition="Library.HasContent(tvshows)">
<param name="content_path" value="videodb://tvshows/"/>
<param name="sortby" value="lastplayed"/>
<param name="sortorder" value="descending"/>
<param name="widget_header" value="$LOCALIZE[626]"/>
<param name="list_id" value="5150"/>
</include>
2019-10-31, 11:06
Thanks, i have still things to learn but when i know it can happen i am ready to read everything i need.
