Full Version: Problem with android TV and 3D films
I have a problem viewing the 3d content that I play in kodi 18.
 The problem is that once I put the 3d movie, the image it shows does not stop showing one eye first and then the other. It is as if you turned to passive 3d glasses, but it does so alone without any order. If at least you could choose which eye to show first for 3d, if left or right, it would be fine. But in this way it is alternating and although the image is not cut, it looks at good times and bad times, as the order of reproduction of images changes at will.
The film is on google drive and i use the addon google drive for sow it.
 Is there any solution?
 Thank you.
(2019-10-21, 08:29)Jexux Wrote: [ -> ]The film is on google drive and i use the addon google drive for sow it.
Copy the video to a local source (usb stick?) and test again.
If there is no change, provide a full debug log (wiki).
The problem is playing with google drive addon. In internal memory, all is ok.
