hi everyone
I have Kodi 18.2 running on Android box and all has been working well up until about 3-4 weeks ago. When I select update library, it goes right up to 57% and then just spins there, doesnt show any movie names and after about 60 seconds app freezes and shuts down and I get kicked out to homescreen.
my movies are on Windows PC with a share, I have not updated anything there at all, my windows updates are manual so it has to be Kodi or add ons.
I tried different scrapers for movies and TV Shows but no go. Also worth noting I have 4 Android boxes running Kodi and this happens on ALL of them (they are different models as well). I have Pihole running as my AD blocker through DNS but even turning that off does not make a difference.
interestingly, if I wipe the whole library, it works however, that takes 4-5 hours to complete so not practical to do that when I want to refresh the library.
any ideas ?
https://paste.kodi.tv/ufenobagiq
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
thanks, how do I export log from android media player?
(2019-10-23, 12:32)omarko Wrote: [ -> ]thanks, how do I export log from android media player?
There is the Kodi Log Uploader add-on.
You can also use a decent Android file manager like X-Plore File Manager, and copy/paste/upload the kodi.log file manually.
If it hangs on the same filename again and again, it might have a filename problem there.
I had a play but got stuck exporting the file ... here is a screenshot though (took it couple weeks ago but essentially is same last entry when it freezes) :
I should also, add, I have 4 Android boxes, 3 different models, they all get stuck on same error and restart the application. its driving me crazy.
https://i.postimg.cc/wxm7x9xZ/IMG-9332.jpg
Please try the log uploader addon mentioned above. Screenshots like that are next to useless unfortunately.
another thought, I just realised, I installed raspberry with Pihole running for the whole network in the house couple months ago, would it be possible its blocking the content from being downloaded ?
EDIT: thats not it, changed the DNS to google DNS and its still not scanning, just gets stuck right away until KODI crashes
(2019-10-26, 22:28)DarrenHill Wrote: [ -> ]Please try the log uploader addon mentioned above. Screenshots like that are next to useless unfortunately.
installed the uploader, here is the log :
https://paste.kodi.tv/eyivilejud
EDIT: do I need to run the update library again and wait for ti to crash and then upload another log ?
Yes, the log should cover the issue. If it's crashing, then you want to upload the previous log (kodi.old.log) after a reboot as that will be the relevant one. I think the addon gives you that option too.
The log basically starts at boot-up and continues until the next reboot/shutdown/crash. At that point the current log is renamed to kodi.old.log, and the previous old log is overwritten.
Also if possible it may be nice to enable debug logging (in
Settings>System Settings>Logging) to gather more information, but if it takes a long time to crash the log may end up too large to upload.
See
debug log (wiki) on the wiki for more details of the above.
As noted above (I guess we cross-posted) that log is from after the reboot. We need kodi.old.log which is the previous one and should hopefully include the crash itself.
(2019-10-26, 22:55)DarrenHill Wrote: [ -> ]As noted above (I guess we cross-posted) that log is from after the reboot. We need kodi.old.log which is the previous one and should hopefully include the crash itself.
I posted the old kodi log as well :
thank you.
any thoughts from anyone now that I posted the logs?
cheers
(2019-10-27, 10:45)omarko Wrote: [ -> ]any thoughts from anyone now that I posted the logs?
Not really, the log file is so short it seems all Kodi does is boot up.
2019-10-27 07:52:39.719 T:24126 NOTICE: Disabled debug logging due to GUI setting. Level 0.
Enable debugging, restart Kodi, do a library update, and then try to provide the log file. If Kodi freezes then, restart/reboot and provide the now kodi.old.log file.
