Full Version: Set sorting widget not working on Nvidia shield
Hi
As the title says I can't access the sorting options when I edit widgets on my Nvidia shield. It works perfectly on my PC.
Nothing simply happens when I click the icon. Same goes for editing the name, so I guess it has something to do with the on screen keyboard not wanting to show.
Any one know a work around or am I doing something wrong?
Hi again.
I realized that this problem seem to be with kodi 18.4. I had 18.0 on my pc and was able to edit the sort criteria (name, dateadded etc.) for widgets.
After I installed 18.4 I can no longer edit them.
Same problem here. Not only on Shield, also on FireTv and MacOS. Its there any way to set this options in the xml? It is really annoying for me, not to be able to set the widgets as i like them :-(
