Full Version: ir-keytable and "enabled kernel protocols"
Hi all,
I am trying to set up my IR remote.
ir-keytable shows that ir-6 kernel protocol is not enabled (only lirc is listed in Enabled Kernel Protocol section):
$ sudo ir-keytable
Found /sys/class/rc/rc0/ (/dev/input/event5) with:
    Name: Media Center Ed. eHome Infrared Remote Transceiver (1934:5168)
    Driver: mceusb, table: rc-rc6-mce
    LIRC device: /dev/lirc0
    Supported kernel protocols: lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp imon
    Enabled kernel protocols: lirc
    bus: 3, vendor/product: 1934:5168, version: 0x0001
    Repeat delay = 500 ms, repeat period = 125 ms
This remote works on another machine whose Enabled kernel protocol has both "lirc" and "rc-6".
How do I enable rc-6 kernel protocol?
sudo ir-keytable -p rc-6,lirc
OR
sudo ir-keytable -p all to turn all of 'em on.
Hint - man ir-keytable Wink
Make sure you don't have lirc running with the default (/dev/lirc0) driver, this will disable all kernel protocol decoders. With your setup rc-6 and the rc6-mce keymap should be enabled by default.
so long,
Hias
(2019-10-29, 13:39)black_eagle Wrote: [ -> ]sudo ir-keytable -p rc-6,lirc
Yes, I tried it before and it didn't work:
$ sudo ir-keytable -p all -t -v
[sudo] password for alexey:
Found device /sys/class/rc/rc0/
Parsing uevent /sys/class/rc/rc0/lirc0/uevent
/sys/class/rc/rc0/lirc0/uevent uevent MAJOR=247
/sys/class/rc/rc0/lirc0/uevent uevent MINOR=0
/sys/class/rc/rc0/lirc0/uevent uevent DEVNAME=lirc0
Input sysfs node is /sys/class/rc/rc0/input25/
Event sysfs node is /sys/class/rc/rc0/input25/event5/
Parsing uevent /sys/class/rc/rc0/input25/event5/uevent
/sys/class/rc/rc0/input25/event5/uevent uevent MAJOR=13
/sys/class/rc/rc0/input25/event5/uevent uevent MINOR=69
/sys/class/rc/rc0/input25/event5/uevent uevent DEVNAME=input/event5
Parsing uevent /sys/class/rc/rc0/uevent
/sys/class/rc/rc0/uevent uevent NAME=rc-rc6-mce
/sys/class/rc/rc0/uevent uevent DRV_NAME=mceusb
/sys/class/rc/rc0/uevent uevent DEV_NAME=Media Center Ed. eHome Infrared Remote Transceiver (1934:5168)
input device is /dev/input/event5
/sys/class/rc/rc0/protocols protocol rc-5 (disabled)
/sys/class/rc/rc0/protocols protocol nec (disabled)
/sys/class/rc/rc0/protocols protocol rc-6 (disabled)
/sys/class/rc/rc0/protocols protocol jvc (disabled)
/sys/class/rc/rc0/protocols protocol sony (disabled)
/sys/class/rc/rc0/protocols protocol rc-5-sz (disabled)
/sys/class/rc/rc0/protocols protocol sanyo (disabled)
/sys/class/rc/rc0/protocols protocol sharp (disabled)
/sys/class/rc/rc0/protocols protocol mce_kbd (disabled)
/sys/class/rc/rc0/protocols protocol xmp (disabled)
/sys/class/rc/rc0/protocols protocol imon (disabled)
/sys/class/rc/rc0/protocols protocol lirc (enabled)
Opening /dev/input/event5
Input Protocol version: 0x00010001
Protocols changed to lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp imon
Testing events. Please, press CTRL-C to abort.
Then it doesn't react on my remote. Maybe something needs to be enabled system-wide?
LIRC is not installed on this system.
