so recently TV show scraping seems to have broken (images fetched ok, but no meta data). From hunting around this seems related to TVDB API version changes - but is there any workaround or fix? Or is the answer "fill in all the details by hand" now?
If TVDb disabled the old API then you have to use TMDb until i release the next version.
(2019-10-31, 12:23)DanCooper Wrote: [ -> ]If TVDb disabled the old API then you have to use TMDb until i release the next version.
TMDB isn't doing so well either.
I have 6 episodes of "Good Omens" all named as "Good Omens - S01Exx" which when it scrapes the episode it gets only the posters back, not the meta data (it does get the right TMDB id for the show though - 71915). But if I hit the API directly (
https://api.themoviedb.org/3/tv/71915/se...pi_key=<my key here>) I get all the metadata. Something's not happy.
A bit of playing with Fiddler shows that it Ember is requesting and receiving season metadata, just it then doesn't populate the episodes with that metadata (credits, plot, etc.)
Any idea when that might be?
Pretty please with sugar on top either fix this or bring out a new version. Can't sync TV shows into Kodi now.
(2019-11-09, 14:44)Chrolm Wrote: [ -> ]Pretty please with sugar on top either fix this or bring out a new version. Can't sync TV shows into Kodi now.
Can't you just watch episodes via files until it's fixed?
(2019-11-09, 14:53)trogggy Wrote: [ -> ] (2019-11-09, 14:44)Chrolm Wrote: [ -> ]Pretty please with sugar on top either fix this or bring out a new version. Can't sync TV shows into Kodi now.
With a manual scape, yes of course. Not saying anything "isn't possible", but the POINT of using EMM is that it scrapes and adds to directly to the local Kodi.
Seems like a complete mess. I see a number of posts of people complaining that various tasks aren't working properly. EMM will scrape images only at the moment for me - metadata for series or episodes still not loading.
I have disabled the TVDB scraper (for data and images) and enabled TMDB for both (with the same data fields).
Scraping is working well enough again (for my use case anyway).
