Full Version: Live TV Playback Freezes
After playing a live tv stream for a few minutes it will freeze. Not seeing anything in the KODI log, but searched around in this forum and one user reported that if using Intel graphics to set the buffer to 2 instead of 3 in KODI system settings. Tried that and playback lasted a little longer, but still froze.
Now this is an Intel NUC, but I used this addon with KODI 17 with no issue. I’ve since upgraded everything to 18.4, and the backend is basically the same too, just has the normal MythTV patches.
Any ideas on how to troubleshoot?
thx
Playback of live tv is fine when viewed from myth frontend. Also can watch live tv using the HD Homerun addon with no issue. It seems somehow the addon is not properly buffering the stream. It’ll play fine for a few minutes, then freeze, stutter, and then resume. Is no one else experiencing this?
So watching recordings does the same thing. It’s not KODI though, because if I move the *.ts file into the library, it plays fine. The addon itself seems to be the problem.
