Full Version: Can't open KODI in my windows 10 2012 vos server
It shows this when I open the kodi application : Wlanapi.dll is missing
I simply googled. Kodi doesn't use/install wlanapi.dll .
https://www.lifewire.com/how-to-fix-wlan...rs-2624238
Its a bad idea to use Windows server for stuff like this, but try installing the WLAN service.  Windows server has most of this stuff removed by default
(2019-11-05, 18:49)Klojum Wrote: [ -> ]I simply googled. Kodi doesn't use/install wlanapi.dll .
Then why it shows this walnapi.DLL missing ?
(2019-11-05, 20:37)jools5000 Wrote: [ -> ]Its a bad idea to use Windows server for stuff like this, but try installing the WLAN service.  Windows server has most of this stuff removed by default
Please brief it more
​​​​​Smile
(2019-11-12, 04:06)Alex0808 Wrote: [ -> ]Then why it shows this walnapi.DLL missing ?
As already indicated, you are using a server OS, and Kodi is not a server application.
I stopped using Windows some 9 years ago, so I'm only guessing what the problem is.
(2019-11-12, 04:07)Alex0808 Wrote: [ -> ]
​​​​​Smile
Can you not do web searches?
See https://www.bonusbits.com/wiki/KB:Wlanap...er_2008_R2 although that's for Server 2008 I doubt the process has changed much.
