Can someone recommend a program to bulk rename my Library Artwork. Also can anyone tell me the exact naming conventions/folder structures for Movies/TV Shows/Music. I have not used Kodi for ages and can't seem to find a definitive wiki guide to all the conventions/folder structures...
My movies are all in separate folders:
Film Archive/2001.folder, A Space Odyssey (1968) [1080p].folder
2001, A Space Odyssey (1968) [1080p].mkv
extrafanart.folder/
fanart1
fanart2
(2019-11-09, 10:43)Z0m8ie Wrote: [ -> ]have not used Kodi for ages and can't seem to find a definitive wiki guide to all the conventions/folder structures...
Check the links in My Signature below.
(2019-11-09, 11:15)Karellen Wrote: [ -> ] (2019-11-09, 10:43)Z0m8ie Wrote: [ -> ]have not used Kodi for ages and can't seem to find a definitive wiki guide to all the conventions/folder structures...
Hey Karellen, Think we spoke some time ago, hope you're keeping well mate. Which link is it in reference to bulk renaming artwork?
Yep, keeping well thanks.
The links are in reference to your question on correct folder structure and Artwork names. The Artwork link has images that will explain proper layout and file naming. Some of you artwork names are incorrect, so best to compare it with the artwork pages.
Others will have to recommend a renamer as I never use any.
for bulk rename of artwork, i'll recommend irfan view.
it has a built in rename batch plugin.
where you can filter/set filename and extensions
https://www.irfanview.com/
(2019-11-09, 12:05)Karellen Wrote: [ -> ]Yep, keeping well thanks.
Where are the artwork pages?
This is not a development question so moving.
(2019-11-09, 12:40)Z0m8ie Wrote: [ -> ] (2019-11-09, 12:05)Karellen Wrote: [ -> ]Yep, keeping well thanks.
The link in Karellen's signature that says "Artwork"...
TBF, I can't see anything about naming conventions on that page though.
(2019-11-09, 12:42)jjd-uk Wrote: [ -> ]This is not a development question so moving.
sorry mate, where we moving?
(2019-11-09, 12:43)jurialmunkey Wrote: [ -> ] (2019-11-09, 12:40)Z0m8ie Wrote: [ -> ] (2019-11-09, 12:05)Karellen Wrote: [ -> ]Yep, keeping well thanks.
Nah, nothing, what do you call discart for example?, disc.png?, discover.png?
