2019-11-10, 10:52
2019-11-11, 10:27
a) there is no donator version any more
b) Do you speak of the "find movie sets for selected movie(s)"?
is there any error in the logs?
2019-11-12, 00:19
22:41:39.400 ERROR o.tinymediamanager.core.movie.connector.MovieToKodiConnector - write C:\Filmoteca\UHD 001\Batman Begins (2005) [UHD Blu-ray] - Special Edition\Batman Begins (2005).UHD Blu-ray.nfo: {}
java.nio.file.NoSuchFileException: C:\Filmoteca\UHD 001\Batman Begins (2005) [UHD Blu-ray] - Special Edition\Batman Begins (2005).UHD Blu-ray.nfo
at sun.nio.fs.WindowsException.translateToIOException(Unknown Source)
at sun.nio.fs.WindowsException.rethrowAsIOException(Unknown Source)
at sun.nio.fs.WindowsFileSystemProvider.newByteChannel(Unknown Source)
at java.nio.file.spi.FileSystemProvider.newOutputStream(Unknown Source)
at java.nio.file.Files.newOutputStream(Unknown Source)
at java.nio.file.Files.write(Unknown Source)
at org.tinymediamanager.core.Utils.writeStringToFile(Utils.java:1511)
at org.tinymediamanager.core.movie.connector.MovieGenericXmlConnector.write(MovieGenericXmlConnector.java:182)
at org.tinymediamanager.core.movie.entities.Movie.writeNFO(Movie.java:1251)
at org.tinymediamanager.ui.movies.actions.MovieRewriteNfoAction$1.doInBackground(MovieRewriteNfoAction.java:63)
at org.tinymediamanager.core.threading.TmmTask.run(TmmTask.java:125)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2019-11-16, 12:31
this just indicates that tmm is unable to write the NFO file...
2019-11-17, 13:25
(2019-11-16, 12:31)mlaggner Wrote: [ -> ]this just indicates that tmm is unable to write the NFO file...What happened?
Could help me?
Thanks in advance.
2019-11-20, 13:57
you need to check path C:\Filmoteca\UHD 001\Batman Begins (2005) [UHD Blu-ray] - Special Edition\Batman Begins (2005).UHD Blu-ray.nfo why tmm is not able to write the NFO file..
this is just the answer from the system that the NFO could not be written (maybe you moved the folder outside of tmm?)
