In my first attempt to run my plugin using python 3 I am getting an error due to kodi65's import of kodiaddon
from kodi65 import addon
File "/home/fbacher/.kodi/addons/script.module.kodi65/lib/kodi65/__init__.py", line 6, in <module>
from kodiaddon import Addon
ModuleNotFoundError: No module named 'kodiaddon'
I know that I can eliminate my dependency on kodi65, but should this work?
(2019-11-12, 16:41)fbacher Wrote: [ -> ]In my first attempt to run my plugin using python 3 I am getting an error due to kodi65's import of kodiaddon
Appears to be caused by script.module.kodi65/lib/kodi65/_init_.py not using relative paths to imports:
from kodiaddon import Addon addon = Addon()
from listitem import ListItem, VideoItem, AudioItem
from itemlist import ItemList
from actionhandler import ActionHandler
from busyhandler import busyhandler as busy
from kodilogging import KodiLogHandler, config
from dialogbaselist import DialogBaseList
from localdb import LocalDB
from player import VideoPlayer
Should be:
from .kodiaddon import Addon addon = Addon()
from .listitem import ListItem, VideoItem, AudioItem
from .itemlist import ItemList
from .actionhandler import ActionHandler
from .busyhandler import busyhandler as busy
from .kodilogging import KodiLogHandler, config
from .dialogbaselist import DialogBaseList
from .localdb import LocalDB
from .player import VideoPlayer
However, once this is fixed there are .decode errors in kodiaddon, due to str.decode does not exist:
self.ID = self.addon.getAddonInfo('id').decode("utf-8")
My assumption is that no decoding is needed (but this needs verification).
(2019-11-12, 17:36)fbacher Wrote: [ -> ]My assumption is that no decoding is needed (but this needs verification).
You can't decode strings in python3 as they are already unicode, not byte strings as they were in python 2.
python:
Python 3.6.8 (default, Oct 7 2019, 12:59:55)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> mystring = "Hello World!!"
>>> print(type(mystring))
<class 'str'>
>>> mystring2 = b"Hello World!!"
>>> print(type(mystring2))
<class 'bytes'>
>>> print(mystring2.decode('utf-8'))
Hello World!!
>>> print(mystring.decode('utf-8'))
File "<stdin>", line 1, in <module>
AttributeError: 'str' object has no attribute 'decode'
I think maybe if you use kodi-six and import xbmc from it you can avoid re-writing all the string code.
scott s.
It seems that kody65 utils.log from
https://github.com/phil65/script.module....5/utils.py has an issue:
File "/home/fbacher/.kodi/addons/script.module.kodi65/lib/kodi65/utils.py", line 55, in log
arg = arg.decode("utf-8", 'ignore')
Is there perhaps a newer version that I should be using?
