Full Version: manually add duplicate episode?
I've got a TV show where one of the episodes comes in two versions, the originally aired version and an extended cut. I have the episodes saved in this format :
Series name 1x01 - Episode Name
and
Series name 1x01 - Episode Name (extended version)
however in TMM both files are collated under the same entry, I've tried cloning the episode but I cannot change which media files are associated with which episode. I used to use Mediaportal and adding this duplicate episode in the TV series plugin there was simple. I can't figure out a way to do that in Kodi using TMM though. What would be the best way to have both episodes listed next to each other, as separate episodes?
