Full Version: problem to apply theme Estouchy on insigna smart tv
Hi, i have a problem to apply theme Estouchy on my insigna smart tv OS based = (android amazon fire tv)
and I would like to know if anyone had a solution ?
Translate by Google Translate
Exactly what problems are you having? What errors etc are shown?
Is your screen a touchscreen? I'm curious as to why you want Estouchy on it, as that's optimised for touchscreens and mice?
(2019-11-14, 18:39)DarrenHill Wrote: [ -> ]Exactly what problems are you having? What errors etc are shown?
My smart tv is not touch but I like Estouchy because I use it on all my other device (Pc phone ...) my problem is i can change theme for Estouchy but in the end to accept yes or no kodi not let me
Fair enough Smile I'm the same, but in my case I use Amber everywhere.
Do you mean it says keep the changes or not you have no way to select yes, or does it not offer for some reason?
(2019-11-14, 19:42)DarrenHill Wrote: [ -> ]Fair enough Smile I'm the same, but in my case I use Amber everywhere.
yes once the theme change kodi wonder if I want to keep the new theme or not but the yes button does not work but the no button works perfectly
translate by google translate sorry for my english i speek french !
(2019-11-14, 20:08)vincent20099 Wrote: [ -> ]
I do not know if it can be important ? but my kodi application do not come from the google store because the store is not installed on my smart tv I installed the apk on the kodi website
No, that shouldn't matter. All the store does is download the apk.
I just tried on my Pi, and I can't select Yes in that window either. So it looks like a skin bug to me - I'll move this thread to the Estouchy section so it can be seen by the people who need it.
(2019-11-14, 20:26)DarrenHill Wrote: [ -> ][font][font]Non, ça ne devrait pas avoir d'importance. [/font][font]Tout ce que le magasin fait est de télécharger l'apk. [/font][/font]
[font][font]Je viens d'essayer mon Pi, et je ne peux pas non plus sélectionner Oui dans cette fenêtre. [/font][font]Cela ressemble donc à un bug cutané. Je vais déplacer ce fil de discussion vers la section Estouchy afin que les personnes qui en ont besoin puissent le voir.[/font][/font]
[font][font]OK, thanks[/font][/font]
Does Etouchy work with a remote that doesn't have a built in mouse?
(2019-11-14, 21:56)snoopyjoe Wrote: [ -> ]Does Etouchy work with a remote that doesn't have a built in mouse?
I do not know because I do not have access to anything other than the no
@vincent20099 - I spoke to the maintainer, and it's actually a deliberate decision (taken from the skin on which Estouchy was based).
There are several places in it where without a mouse / touchscreen the user will get stuck, as there are no navigation options built into the skin as it's designed for touchscreen so wouldn't need them.
So unfortunately it's a feature rather than a bug, and isn't something that will be changed. So you'll need to use a different skin on your TV.
(2019-11-14, 23:03)DarrenHill Wrote: [ -> ]@vincent20099 - I spoke to the maintainer, and it's actually a deliberate decision (taken from the skin on which Estouchy was based).
Thank you for your help
