2019-11-15, 10:50
Hello.
Until recently tinyMediamanager worked very well.
Today I tried to read some movies after a 3 weeks break.
Unfortunately this doesn't work anymore.
I don't know what it could be lying about.
The movies are on a NAS, tinyMediamanager is on Linux Mint 18.3.
Thanks for your help.
Error report:
09:19:20.464 WARN org.tinymediamanager.scraper.http.Url - problem fetching the url: HTTP 404 / Not Found | http://thetvdb.com/banners/actors/44914.jpg
09:19:20.598 WARN org.tinymediamanager.scraper.http.Url - problem fetching the url: HTTP 404 / Not Found | http://thetvdb.com/banners/actors/44914.jpg
09:19:20.686 WARN org.tinymediamanager.scraper.http.Url - problem fetching the url: HTTP 404 / Not Found | http://thetvdb.com/banners/actors/44914.jpg
09:19:20.772 WARN org.tinymediamanager.scraper.http.Url - problem fetching the url: HTTP 404 / Not Found | http://thetvdb.com/banners/actors/44914.jpg
09:19:20.855 WARN org.tinymediamanager.scraper.http.Url - problem fetching the url: HTTP 404 / Not Found | http://thetvdb.com/banners/actors/44914.jpg
09:19:20.934 WARN org.tinymediamanager.scraper.http.Url - problem fetching the url: HTTP 404 / Not Found | http://thetvdb.com/banners/actors/44914.jpg
09:19:38.668 ERROR o.tinymediamanager.core.movie.connector.MovieToKodiConnector - write /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.nfo: {}
java.nio.file.AccessDeniedException: /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.nfo
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107)
at sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:214)
at java.nio.file.spi.FileSystemProvider.newOutputStream(FileSystemProvider.java:434)
at java.nio.file.Files.newOutputStream(Files.java:216)
at java.nio.file.Files.write(Files.java:3292)
at org.tinymediamanager.core.Utils.writeStringToFile(Utils.java:1511)
at org.tinymediamanager.core.movie.connector.MovieGenericXmlConnector.write(MovieGenericXmlConnector.java:182)
at org.tinymediamanager.core.movie.entities.Movie.writeNFO(Movie.java:1251)
at org.tinymediamanager.core.movie.entities.Movie.setMetadata(Movie.java:888)
at org.tinymediamanager.ui.movies.dialogs.MovieChooserDialog.actionPerformed(MovieChooserDialog.java:473)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at com.jtattoo.plaf.BaseButtonListener.mouseReleased(BaseButtonListener.java:61)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
at java.awt.Dialog.show(Dialog.java:1084)
at java.awt.Component.show(Component.java:1671)
at java.awt.Component.setVisible(Component.java:1623)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1005)
at org.tinymediamanager.ui.dialogs.TmmDialog.setVisible(TmmDialog.java:239)
at org.tinymediamanager.ui.movies.actions.MovieSingleScrapeAction.processAction(MovieSingleScrapeAction.java:67)
at org.tinymediamanager.ui.actions.TmmAction.actionPerformed(TmmAction.java:35)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
09:19:39.015 WARN org.tinymediamanager.core.Utils - rename problem: /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv -> /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv
09:19:40.021 WARN org.tinymediamanager.core.Utils - rename problem: /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv -> /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv
09:19:41.026 WARN org.tinymediamanager.core.Utils - rename problem: /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv -> /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv
09:19:42.031 WARN org.tinymediamanager.core.Utils - rename problem: /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv -> /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv
09:19:43.039 WARN org.tinymediamanager.core.Utils - rename problem: /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv -> /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv
09:19:44.042 ERROR org.tinymediamanager.core.Utils - Failed to rename file /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv
09:19:44.044 ERROR org.tinymediamanager.core.movie.MovieRenamer - Could not move MF '/home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.mkv' to '/home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A Beautiful Mind - Genie und Wahnsinn (2001) HEVC-1080p AC3-6ch.mkv'
09:19:45.847 ERROR o.tinymediamanager.core.movie.connector.MovieToKodiConnector - write /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.nfo: {}
at org.tinymediamanager.core.movie.MovieArtworkHelper.setArtwork(MovieArtworkHelper.java:827)
at org.tinymediamanager.core.movie.entities.Movie.setArtwork(Movie.java:1001)
at org.tinymediamanager.ui.movies.MovieChooserModel$ArtworkScrapeTask.doInBackground(MovieChooserModel.java:380)
at org.tinymediamanager.core.threading.TmmTask.run(TmmTask.java:125)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
09:19:46.082 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/poster.jpg
09:19:46.314 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/logo.png
09:19:46.406 ERROR o.tinymediamanager.core.movie.connector.MovieToKodiConnector - write /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/A.Beautiful.Mind.-.Genie.und.Wahnsinn.nfo: {}
at org.tinymediamanager.ui.movies.MovieChooserModel$TrailerScrapeTask.doInBackground(MovieChooserModel.java:446)
09:19:46.419 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/fanart.jpg
09:19:47.088 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/poster.jpg
09:19:47.327 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/logo.png
09:19:47.425 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/fanart.jpg
09:19:48.092 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/poster.jpg
09:19:48.334 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/logo.png
09:19:48.435 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/fanart.jpg
09:19:49.098 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/poster.jpg
09:19:49.340 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/logo.png
09:19:49.442 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/fanart.jpg
09:19:50.107 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/poster.jpg
09:19:50.346 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/logo.png
09:19:50.448 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/fanart.jpg
09:19:51.109 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/poster.jpg.1573805985782.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/poster.jpg
09:19:51.110 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image http://image.tmdb.org/t/p/w500/uYDf7ktXn...TusyeZ.jpg - renaming temp file failed: poster.jpg
09:19:51.347 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/logo.png.1573805985811.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/logo.png
09:19:51.348 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...848364.png - renaming temp file failed: logo.png
09:19:51.366 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearlogo.png
09:19:51.449 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/fanart.jpg.1573805985790.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/fanart.jpg
09:19:51.451 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...daba2a.jpg - renaming temp file failed: fanart.jpg
09:19:51.688 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearart.png
09:19:51.897 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/banner.jpg
09:19:52.374 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearlogo.png
09:19:52.697 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearart.png
09:19:52.912 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/banner.jpg
09:19:53.383 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearlogo.png
09:19:53.704 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearart.png
09:19:53.918 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/banner.jpg
09:19:54.389 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearlogo.png
09:19:54.714 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearart.png
09:19:54.924 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/banner.jpg
09:19:55.399 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearlogo.png
09:19:55.721 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearart.png
09:19:55.936 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/banner.jpg
09:19:56.400 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/clearlogo.png.1573805991112.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearlogo.png
09:19:56.401 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...848364.png - renaming temp file failed: clearlogo.png
09:19:56.722 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/clearart.png.1573805991351.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/clearart.png
09:19:56.723 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...0e3a12.png - renaming temp file failed: clearart.png
09:19:56.869 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/thumb.jpg
09:19:56.937 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/banner.jpg.1573805991463.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/banner.jpg
09:19:56.939 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...e208a2.jpg - renaming temp file failed: banner.jpg
09:19:57.279 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/disc.png
09:19:57.408 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/keyart.jpg
09:19:57.875 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/thumb.jpg
09:19:58.284 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/disc.png
09:19:58.416 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/keyart.jpg
09:19:58.885 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/thumb.jpg
09:19:59.290 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/disc.png
09:19:59.425 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/keyart.jpg
09:19:59.894 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/thumb.jpg
09:20:00.296 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/disc.png
09:20:00.430 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/keyart.jpg
09:20:00.903 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/thumb.jpg
09:20:01.309 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/disc.png
09:20:01.441 WARN org.tinymediamanager.core.Utils - rename problem (fallbacl): /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/keyart.jpg
09:20:01.905 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/thumb.jpg.1573805996403.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/thumb.jpg
09:20:01.907 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...0737a4.jpg - renaming temp file failed: thumb.jpg
09:20:02.310 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/disc.png.1573805996731.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/disc.png
09:20:02.312 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...f7a66f.png - renaming temp file failed: disc.png
09:20:02.442 ERROR org.tinymediamanager.core.Utils - Failed to rename file /tmp/keyart.jpg.1573805996945.part to /home/XXX/YYY/Filme/A Beautiful Mind - Genie und Wahnsinn (2001)/keyart.jpg
09:20:02.443 ERROR org.tinymediamanager.core.tasks.MediaEntityImageFetcherTask - fetch image https://assets.fanart.tv/fanart/movies/4...3689a6.jpg - renaming temp file failed: keyart.jpg
Error report:
