2019-11-19, 16:11
(2019-11-19, 16:06)jjd-uk Wrote: [ -> ]Generate a debug Log_file (wiki) to see what's going onBah, blow looking at the log @black_eagle is a dev ninja now he can run in a debugger
(2019-11-19, 14:48)black_eagle Wrote: [ -> ]I'm currently listening to Dark Side of the Moon in DTS. More accurately,Hi,
General
Complete name : /media/sdd1/Dark side of the moon DTS/Track 4.wav
Format : Wave
File size : 71.4 MiB
Duration : 7 min 4 s
Overall bit rate mode : Constant
Overall bit rate : 1 411 kb/s
Writing application : gvfs-cdda using libcdio 0.83 x86_64-pc-linux-gnu
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 411.2 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 71.4 MiB (100%)
Kodi tells me it's 32bit audio. My 44.1/24 has gone up in bits and your 96/24 has come down !! To be honest, as long as the stuff coming out of the speakers sounds good (and it really, really does !) then I'm not too bothered about the label being wrong. I do appreciate that you'd like it to be right (and so would I) but there are probably more important things to fix.
I've not yet tried re-encapsulating any tracks into a different container to see if that makes a difference.
(2019-11-20, 01:19)HeresJohnny Wrote: [ -> ]What you have there is DTS-HD (MA) or DTS 96/24 and depending on where and how you reproduce it you may only play the DTS Core at 16/48khz. Instead of changing the container, try renaming it to .dtshd or whatever format it really is.
