2020-09-11, 11:23
Does anyone know how to get the add-on to play the next episode in a season of a TV series automatically? Or is there a general Kodi setting I can use?
(2020-09-11, 21:11)snoopyjoe Wrote: [ -> ]@Airw0lf_ I believe most people just use the export feature to use abilities like play next episode or have the Kodi setting to play next file.
@markeymark Yes it will play any content associated with your Prime account. I believe this Prime and SlingTV are the only addons to get premium channels like HBO in the USA at the moment. PSvue was another option but the service was discontinued.
(2020-08-17, 01:58)Sumanyu Wrote: [ -> ]I am trying to use the Amazon VOD addon but whenever I play a video, the blue circle keeps on rolling and the video does not start. Anyone have any solution? The debug log is here
(2020-08-22, 19:52)rocko Wrote: [ -> ]This works great on Kodi 18 and 19 except for two things, watched movie doesn,t check off and no option for resume point, always starts over.
Am I missing something in the settings or do these functions not work.
(2020-08-29, 22:59)heysoundude Wrote: [ -> ]I tried for both the leia and the matrix zips, same message both times.
(2020-08-30, 13:48)dormamu Wrote: [ -> ]I'm unable to login into the app. The reason why is clear. Amazon identifies the login as an unusual sign-in attempt. I receive a text message from Amazon with a redirect where I can approve the login but this won't allow me to sign in into the app. I keep receiving the same error and I keep receiving approval requests from Amazon
Anyone else experiencing this problem? Anyone knows a workaround?
(2020-08-31, 03:11)teriyaki Wrote: [ -> ]Haven't check the status of the Amazon VOD addon in a while... Is it still a goal to get it in the official repo for the Kodi 19 release?
(2020-09-05, 13:05)AbRASiON Wrote: [ -> ]Does this work currently on Kodi 18? It sounds like people are having problems.
(2020-09-06, 02:37)AbRASiON Wrote: [ -> ]Never mind, I got the plugin working, not the fastest performer, but it does work.
Does it get faster at caching thumbs or anything?
(2020-09-06, 14:55)Utter Wrote: [ -> ]Yes, I have the same issue. It seems an almost trivial act to trigger Amazon's 'unusual sign-in' response, particularly if you use a VPN.
Did you find a solution at all?
(2020-09-11, 06:05)picard12 Wrote: [ -> ]I have some problems. When I try to access my series list, the plugin fails. vod 8.8 leila
(2020-09-11, 11:23)Airw0lf_ Wrote: [ -> ]Does anyone know how to get the add-on to play the next episode in a season of a TV series automatically? Or is there a general Kodi setting I can use?
(2020-09-11, 14:44)markeymark Wrote: [ -> ]If i have Prime USA with Showtime/HBO channels, will this add on get me them or just the VOD?
(2020-09-16, 12:07)Varstahl Wrote: [ -> ](2020-08-29, 22:59)heysoundude Wrote: [ -> ]I tried for both the leia and the matrix zips, same message both times.
Those are repos zips, not addons. You need to select the .zip while adding a new repository. After that you can download the addons from the repos.
Note: make sure you select leia for Kodi 18 or matrix for Kodi 19, or there'll be hell to pay in cleaning up.
In Terminal, it's just a wget with the full URL for the version-specific zip file, is it not?
(2020-09-17, 20:37)Varstahl Wrote: [ -> ]One of the two: enable "Bypass HDCP" in InputStream.Adaptive, or download and setup playback to use the native app.
(2020-09-17, 22:51)Tedkiller Wrote: [ -> ]It stopped being possible to get 4k in the Kodi addon on the Shield some time ago. Not sure why. 1080 is the most you can get now, but at least you get proper audio (unlike the 'proper' Amazon app which only outputs stereo on the Shield). But you should be able to get the Amazon app working for 4k content (just with stereo). Basically Amazon on the Shield is a PITA these days - I have to use the TV's native app, and put up with their crap interface.(2020-09-17, 20:37)Varstahl Wrote: [ -> ]One of the two: enable "Bypass HDCP" in InputStream.Adaptive, or download and setup playback to use the native app.
Bypass HDCP is ticked and let me have 1080p instead of 720p but no 4K.
Use amazon app give me a black screen
(2020-09-19, 17:41)rob_l12 Wrote: [ -> ]Thanks for your feedback, I was going nuts trying to get 4K and focusing on the video, I didn't notice the stereo issue with the native crappy app. what a shame.(2020-09-17, 22:51)Tedkiller Wrote: [ -> ]It stopped being possible to get 4k in the Kodi addon on the Shield some time ago. Not sure why. 1080 is the most you can get now, but at least you get proper audio (unlike the 'proper' Amazon app which only outputs stereo on the Shield). But you should be able to get the Amazon app working for 4k content (just with stereo). Basically Amazon on the Shield is a PITA these days - I have to use the TV's native app, and put up with their crap interface.(2020-09-17, 20:37)Varstahl Wrote: [ -> ]One of the two: enable "Bypass HDCP" in InputStream.Adaptive, or download and setup playback to use the native app.
