Full Version: No DTS-HD
All,
Can you please help me out?
I've build a new HTPC, changed my GPU to AMD, so I can decode HEVC 10 bit. Works fine.
Only one problem.
I cannot decode DTS-HD (DTS-X) anymore. Sometimes DTS format is buggy as well. No issues on Atmos, True HD , and DD.
Before this GPU, I had no problems with audio at all.
With passthrough disabled, it works fine, but I don't want to do that.
some extra info:
I'm using a dual boot. On win10 no issues at all. But I want to use LibreElec.
Receiver: Pioneer VSX 1131
TV: Philips 65PUS7601
HTPC: Intel i36100 @ 3,7GHZ, AMD Radeon RX580 8.GB MSI
LibreElec: 9.1.502. I also tried other versions. Sometimes normal DTS stutters on Leia versions. On Krypton no sound at all.
I can also provide a log: http://ix.io/22g7
Kind regards!
Please file a bug with the mesa / kernel people. Some AMD GPUs have bugs in that regard. Sometimes they work with 1920x1080 at 60 hz.
From kodi pov all is fine:
Quote:2019-11-19 11:44:54.728 T:140526266992384  NOTICE:     Device 3
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_deviceName      : hdmi:CARD=HDMI,DEV=2
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_displayName     : HDA ATI
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_displayNameExtra: PIO AV Receiver
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_channels        : FL, FR, LFE, FC, BL, BR, BLOC, BROC
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2019-11-19 11:44:54.728 T:140526266992384  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
