Full Version: TVDB - TV Show scraper (XML)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
Image TheTVDB Scraper for TV Shows
**** MODERATOR NOTICE ****:
This scraper is BROKEN and removed from the Official Kodi Repository
Please update to the newest TVDB v4 scraper.
See... https://forum.kodi.tv/showthread.php?tid=368272
See this post for more information... https://forum.kodi.tv/showthread.php?tid...pid3100373
Site used: https://www.thetvdb.com/
Status: Working for Kodi v13 and later. Available scraper functions will depend on Kodi version in use.
Developed by: @scudlee
Currently maintained by: @olympia
About
TheTVDB scraper for TV Shows is an alternate scraper (wiki) for TV Shows used by KODI. (It was replaced as the default scraper during Nov 2018 by TheMovieDB)
The scraper relies on matching your TV Show folder name to TV Show titles at TheTVDB site. Episodes are matched on the Season/Episode numbering of your filename. (S01E01)
This scraper will download the following:
Artwork:
• TV Show- Banner, Poster & Fanart
• Season- Banner, Poster
• Episodes- Thumbs
Metadata: Numerous.
Guides
The wiki page for this scraper can be found here:
The following links may assist with setting up your library:
How to Create your Video Library (wiki)
Before posting about a problem read this post... Common Problems
Release Notes
v3.2.4 & v2.1.4 24 Jan 2020
- Fix for changes in TVDB search API https://github.com/xbmc/repo-scrapers/pull/172 and https://github.com/xbmc/repo-scrapers/pull/173
v3.2.3 05 Jan 2020
- Fix blooper introduced in v3.2.2 https://github.com/xbmc/repo-scrapers/pull/168
v3.2.2 04 Jan 2020
- Fix failed scraping when Overview is missing from tv show https://github.com/xbmc/repo-scrapers/pull/167
v3.2.1 & v2.1.1 25 Nov 2019
- Fixes image previews in the Choose Art dialogue
v3.2.0 20 Nov 2019
- Fixes to searching and scraping of artwork and metadata in response to the TVDB v3 site and API rollout
- More info at TVDB... https://forums.thetvdb.com/viewtopic.php...60#p163460 and https://forums.thetvdb.com/viewtopic.php?f=122&t=60239
Reserved
Notice:
metadata.tvdb.com-3.2.0 for Krypton and higher is now available.
metadata.tvdb.com-2.1.0 for Jarvis and earlier versions is now available
You can...
1. Wait upto 24 hours for your repository and add-on to update automatically, assuming you have not disabled these settings
2. Go to Settings > Add-ons and force a repository update from the left sideblade menu by selecting Check for updates. You may need to wait until the update reaches the servers in your part of the world.
3. Download and install from zip from the following links...
  1. Krypton (v17) and later - http://mirrors.kodi.tv/addons/krypton/me....tvdb.com/
  2. Jarvis (v16) and earlier - http://mirrors.kodi.tv/addons/gotham/metadata.tvdb.com/
Thanks @olympia
Release Notes
TheTVDB are continuing to work on their site and API. Sudden changes may occur. This scraper should be considered unstable until all works at TheTVDB are complete.
v3.2.0 and v2.1.0
Thank you! It's working for me.
Will it eventually be fixed for isengard?
(2019-11-20, 05:52)Oceanic Wrote: [ -> ]Will it eventually be fixed for isengard?
May I ask what you’re doing on v15 in this day and age?
No. You will need to update to at least v17 if you want to continue to use TheTVDB scraper.
Is there any reason you are still on Isengard? Do you need help updating?
(2019-11-20, 07:00)Karellen Wrote: [ -> ]
i use the dsplayer version/branch of kodi, to use graphical enhancements to videos (madvr, svp, ffdshow etc). I also tend to modify the coding of skins heavily for my own preferences. last time it took a few months to get everything the way that i like it. im not looking forward to starting mostly from scratch. having a version of kodi usable for a few months while i build an updated version of kodi on the same setup is also a cumbersome part for me. youtube not being at 120fps looks distracting to me. ive been wanting to add netflix and amazon prime tv though, so that's an upside im trying to motivate myself with.
@Oceanic
Updated for Gotham - Jarvis.
See previous posts for instructions to install
it's still not working for me
Great work @olympia !
(2019-11-20, 10:57)GrimReaperLayer Wrote: [ -> ]it's still not working for me
Please provide a Debug Log which captures an Update Library.
(2019-11-20, 11:05)Karellen Wrote: [ -> ]
where do i find it
(2019-11-20, 11:29)GrimReaperLayer Wrote: [ -> ]where do i find it
Click the link to follow the instructions --->>> Debug Log <<<---
Thanks @Karellen and the rest of the team (btw, Kodi DSPlayer is on 17.6, so I don't see why @Oceanic asked that question but glad to see extended support for old versions, a class act).
You handled this in a really professional way, with constant updates and all the info needed to handle the "crisis". It's been much appreciated.
