2019-11-21, 17:46
2019-11-26, 14:23
playlist for what?
how should that look like?
2019-11-26, 15:33
i wasn't sure anyone would be interested in this but maybe separate tab in the GUI (i.e. Movies, Movie sets, Tv Shows, Playlists)
TMM would then need to be able to read .m3u in a specified directory
View (same format as the movie sets)
- List all playlists in the directory
- Expand node will list movies in the playlist
Basic
- Create a playlist
- Add/Remove movies from the local db to/from a playlist
Advanced
- Fetch and create lists from TMDB for example - https://www.themoviedb.org/documentation/api/discover
Basic
- Create a playlist
Advanced
2019-11-26, 16:54
no sorry, another module would need more resources than we have to invest.
2019-11-26, 17:31
cheers
thanks for considering
Edit: Alternative solution - https://forum.kodi.tv/showthread.php?tid=140494
