2019-11-26, 00:33
2019-11-26, 13:34
(2019-11-26, 00:33)burekas Wrote: [ -> ]Hi,Just brainstorming here as I don't know but did you try deleting the addons and then re adding them in the order of preference or reverse preference?
I want to change the order of the addons in the Subtitles Dialog, is it possible?
2019-11-26, 19:26
Yes, it seems that it is working that way.
But is there any other way to do it instead of uninstall and install it?
2021-10-07, 17:54
(2019-11-26, 13:34)cscott1 Wrote: [ -> ](2019-11-26, 00:33)burekas Wrote: [ -> ]Hi,Just brainstorming here as I don't know but did you try deleting the addons and then re adding them in the order of preference or reverse preference?
This way doesn't work anymore in Kodi Matrix.
How can I change the order to be as I want to?
2022-04-09, 18:12
Anyone knows a way to reorder subtitles services?
