Hi Everyone,
Has anyone got animated fanart working on this skin or is it something that @
ronie will need to add?
Appreciate your time,
Cam
(2019-11-26, 17:59)PatK Wrote: [ -> ]This really should be in the feature request forum. But as you've posted here in this skin forum, I've have successfully used T! with animated posters with some of my collection https://forum.kodi.tv/showthread.php?tid=215727 and utilize full sized animgifs for backdrops. This will give you most of the low down https://forum.kodi.tv/forumdisplay.php?fid=71
What effect are you looking for, perhaps there is work-round that might be more effective?
Hi PatK, apologies for not posting in the correct section, I thought Kodi at its core supported animated fanart and it was on the Skin to display it.
I have had a fiddle with the methods you linked and could get animated posters to display by manually selecting them via the choose art setting.
What I was really after was for Transparency! to automatically display like MQ8 does.
(2019-11-26, 19:01)Camcs1 Wrote: [ -> ]Transparency! to automatically display like MQ8 does
I'm unfamiliar with that skin, in which way does it differ and which way would you like T! to handle anims that are any different from what it does now? I guess having skins that all have the same features would be a bit moot. What does T! have that makes you ask for this feature in this skin, vs just using MQ8
I personally find video's as fanart and posters would likely slow down the interface to the point it might become sluggish, reminds me of the youtube option of playing a few frames on hover. Given that programs like
Add-on:Cinema Experience (wiki) can set-up to add and insert shorts at various points in a presentation, I don;'t search for more add-ons. I suppose without a lot of skinning effort, it might be possible to auto-engage trailers for each poster, but the load times would be a killer and hardware dependant.
(2019-11-26, 21:26)PatK Wrote: [ -> ] (2019-11-26, 19:01)Camcs1 Wrote: [ -> ]Transparency! to automatically display like MQ8 does
I personally find video's as fanart and posters would likely slow down the interface to the point it might become sluggish, reminds me of the youtube option of playing a few frames on hover. Given that programs like Add-on:Cinema Experience (wiki) can set-up to add and insert shorts at various points in a presentation, I don;'t search for more add-ons. I suppose without a lot of skinning effort, it might be possible to auto-engage trailers for each poster, but the load times would be a killer and hardware dependant.
I'm not a user of Aeon MQ8 either I just tried it when testing animated artworks and noticed that it was able to pick them up automatically. By that I mean it, displayed the animated versions when the correct file was provided as opposed to transparency! where each artwork has to be individually set via the chose art menu.
For me really the advantage that Transparency! has is really just familiarity as I've been using it for some time and am really happy as to how the UI functions in general. My initial draw to Transparency! was that it supported basically every artwork available at the time, if you look at the addon description its described as a Fanart Skin.
However I have to agree with you on the performance point as I have also noticed slowdowns when using lots of animated fan-art on one screen, I can see views such as wall really struggling with all those GIF's.
It's more of a would be nice than an essential feature if you get what I mean
(2019-11-26, 22:02)Camcs1 Wrote: [ -> ]displayed the animated versions when the correct file was provided
Ok default artwork is an anim file if available, I can see that would be a possibility especially if scrapers would pick up on it. I envision the day all backdrops are are full cycle animations and video presentations of upcoming, favourites and trailers make selection a candy bar experience, just by saying 'I want that one'. ATM: I choose swift browsing over glory of the visuals unless I have visitors, then I change gears and then they never knew what hit them
P.S. When T! added support for extended artwork and posters, I was all over it until my set-up started to chug.
