I recently changed laptops. Both are running Windows 10. My old laptop I was able to browse to my Raspberry Pi by entering the IP in File manager: \\192.168.x.x
On the new machine I get an error that Windows cannot access \\....
Maybe I'm searching wrong, but I cannot seem to find a way around this?
My Raspberry Pi is connected to my living room TV with an external hdd. Normally I could add/remove files from my Windows machine over File Manager. Now that seems to not be the case. Does anyone have a solution or a workaround? Running all the latest LE and Kodi builds.
Careful with the term 'builds', we are quite allergic to it because it tends to refer to video piracy add-ons.
Your current Kodi setup uses a newer version of the SMB network protocol.
It used to be SMBv1, but since the whole worldwide WannaCry disaster, Microsoft finally woke up and fixed a lot of security holes.
This results in SMBv2 (and higher), which is also the default in LibreELEC.
SMBv2 requires two major changes: the server machine must have a user with a password, and also network browsing is no longer enabled.
Meaning, you will need to set up a network connection from your Windows machine to the LibreELEC device.
Also don't forget to check any firewall settings on your Windows box.
(2019-11-26, 14:18)Klojum Wrote: [ -> ]Careful with the term 'builds', we are quite allergic to it because it tends to refer to video piracy add-ons.
Sorry about the builds
No intention of that.
How do I setup a new connection then from Windows? I have a user/pass already setup on my Pi. Or is there a better way to connect my Win 10 machine to my Pi?
I don't use Windows myself anymore, I stopped doing that some 9 years ago.
But I'm sure there is some option like "Connect to server" somewhere in the File Explorer, and a input box appears for network user credentials.
Alternatively you could change the SMB minimum protocol in the LibreELEC Settings addon.
This is not recommended, obviously.
(2019-11-26, 15:17)Klojum Wrote: [ -> ]I don't use Windows myself anymore, I stopped doing that some 9 years ago.
Problem solved. I did not have SMB enabled on my Kodi box as I thought. I set min to v2 and max to v3 and confirmed user/pass. I can now browser directly from File Explorer. Thanks for pointing me in the right direction.
