I version 18 of KODI
I found the disappearance of those seconds responsible for buffering, which was on the side . How can I give it back?
Looks to be a skin issue or an add-on issue. What skin & add-on are you using?
You are using a 3rd party add-on. I suggest you contact the developers of that add-on for your support.
(2019-11-30, 03:02)Klojum Wrote: [ -> ]You are using a 3rd party add-on. I suggest you contact the developers of that add-on for your support.
No I don't use any add-on , it's original KODI from the official website and no plugins.
(2019-11-30, 02:59)PatK Wrote: [ -> ]Looks to be a skin issue or an add-on issue. What skin & add-on are you using?
