2019-12-01, 02:21
My setup is running on Lubuntu 18.04
Kodi seems to work fine for streaming. I can connect to Mythtv backend without issues. The problem is playback of OTA recorded TV, it is choppy and lags. I have combined Mythtv backend and Kodi into a single pc (so it connects to itself). The storage is also local. If I connect to Mythtv backend from another Kodi machine such as my Raspi 3, the playback works as expected. The problem seems to be isolated to just my combo pc.
I want to know if my setup can be fixed/optimized or should I look at getting something newer?
I'll be the first to admit the computer I have is rather old even for use with Linux. It has 1GB of RAM
Here is what I know, I am sure there may be further questions so ask away!
jeremy@kodihead:~$ free -h
total used free shared buff/cache available
Mem: 904M 382M 68M 84M 452M 308M
Swap: 2.0G 76M 1.9G
jeremy@kodihead:/var/log$ lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation 82Q35 Express Integrated Graphics Controller (rev 02)
Subsystem: Hewlett-Packard Company 82Q35 Express Integrated Graphics Controller
Kernel driver in use: i915
Kernel modules: i915
00:02.1 Display controller: Intel Corporation 82Q35 Express Integrated Graphics Controller (rev 02)
00:03.0 Communication controller: Intel Corporation 82Q35 Express MEI Controller (rev 02)
Subsystem: Hewlett-Packard Company 82Q35 Express MEI Controller
jeremy@kodihead:/var/log$ sudo lshw -C display
[sudo] password for jeremy:
*-display:0
description: VGA compatible controller
product: 82Q35 Express Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:16 memory:f0100000-f017ffff ioport:1230(size=8) memory:e0000000-efffffff memory:f0000000-f00fffff memory:c0000-dffff
*-display:1 UNCLAIMED
description: Display controller
physical id: 2.1
bus info: pci@0000:00:02.1
version: 02
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: latency=0
resources: memory:f0180000-f01fffff
I have tried upgrading graphics drivers as listed in this post. https://askubuntu.com/questions/1065852/...ics-driver That actually made the problem worse as I got some odd pixelation on screen. When that happened, I removed the updated drivers. Thanks in advance for your advice!
Swap: 2.0G 76M 1.9G
*-display:0
physical id: 2
version: 02
width: 32 bits
clock: 33MHz
physical id: 2.1
version: 02
width: 32 bits
clock: 33MHz
