(2019-12-12, 12:38)tabun Wrote: [ -> ] (2019-12-07, 11:37)anbessaw7 Wrote: [ -> ]Tags can be sorted but this will depend on the skin you are using. At the same time, you can also tweak the premiered dates to get a chronological (or any order) using tags but utilizing playlists is way more efficient.
I have been looking for and not found a utility to properly/intuitively manage playlists outside kodi - please let me know if you do
And that's why I originally posted here, albeit I was asking the wrong question I guess. Manuel has worked wonders with TMM and I guess I just figured this would be an easy thing for him but I really have no idea about the complexity. I tried editing the sort title within a tag (i.e. MCU001, MCU002, etc) and that works fine, but the movies are then sorted like that everywhere in Kodi and I didn't want that. I'm going to have to switch from the Estuary skin I guess. Some others seem to offer more options for this.
I actually made a request for a playlist manager module for TMM
here ... and this was after not being able to find a solution. Anyway, I am not familiar with Estuary but I will explain how I use the sort titles/tags/playlists so you can atleast get your playlists working in Kodi for now.
Sort titles should be used for the global library. For instance, the Captain America collection sort titles would be Captain America 1, Captain America 2, Captain America 3. This way, if you pull up your entire library it will be correctly placed alphabetically (i.e. with all the other C movies) and also respect the order of the trilogy (Avenger>Winter>Civil). This applies to all movie collections with some exceptions (movies in a collection whose titles don't need sorting)
Tags you can create your own custom tags or use the ones you already scraped. For mcu, use "Marvel Cinematic Universe"
https://www.themoviedb.org/keyword/18054...uage=en-US. In Kodi, create a smart playlist with the rule
tags contains marvel cinematic universe, and order by year descending. This will give you a playlist with all 23 movies in release order.
- If you prefer the chronological/custom order - the quickest way would be to create a basic playlist from within the same smart list you just created above. Just start queuing items in chronological order, when you are done go to current playlist and save it. -
OR- skip creating the smart playlist above and queue items straight from your library if that's easier for you.
- For Tarantino movies, instead of tags set the rule type based on directors when creating the smart playlist and browse for "Quentin Tarantino"
- For Alien movies, they should already contain the alien tag in the metadata so just set the rule tags contains aliens
For the MCU specifically, If you decide to incorporate @
Karellen suggestion into the scenario - you won't need the basic playlists, but you will need to adjust the local file names to get the chronological order.
