Full Version: Smart TV / Rai TV addon
Hello everyone
I installed it on the Raspbery 4, 1Gb, and I'm using it with the add-on DVB TV Hat always on the raspberry, I had some problems figuring out how to search for programs, solved this I noticed that I can't get a continuation of the selection to my liking maybe it's me that I don't use a correct procedure, I arrive at my request and it is possible to install a program to also have a smart TV ??
Thanks  !!!
sorry I was wrong where I put it .....
I already moved your other thread to the garbage bin as a duplicate.
But I'm not sure in which forum section your question in this thread needs to be.
Could be perhaps clarify your main question a bit more?
(2019-12-07, 19:17)Klojum Wrote: [ -> ]I already moved your other thread to the garbage bin as a duplicate.
Thanks for answering Klojum !!
My problem and this, I wanted to add a broadcast that is transmitted via the web in the Rai package called Raiplay
I think to get this you need to install the Smart TV software or am I wrong ??
(2019-12-07, 19:34)Klojum Wrote: [ -> ]Have a look here : https://forum.kodi.tv/showthread.php?tid=155922
I have seen thanks, now I have to succeed to install it on the raspberry, is there a procedure that I can do it directly through Kodi?
