2019-12-09, 14:28
2019-12-09, 14:56
How are we to make any kind of suggestions when we have no clue as to what kind of HTPC you have or which components you are using..?
2019-12-09, 15:16
(2019-12-09, 14:56)Klojum Wrote: [ -> ]How are we to make any kind of suggestions when we have no clue as to what kind of HTPC you have or which components you are using..?
sorry about that here is my specs and my tv is a samsung 65"4k hdr tv
2020-04-11, 13:19
any help on this cheers
2020-04-11, 14:25
(2019-12-09, 14:28)turbotec Wrote: [ -> ]do i change anything
I'm guessing from the screenshot you are using Windows as the operating system.
Normally the latest video drivers are advised.
Since you are reporting no issues or problems, I assume Kodi is working well.
Are there any problems that require Kodi settings to be different?
2020-04-13, 10:01
(2020-04-11, 14:25)Klojum Wrote: [ -> ]i was lookin some info on the player setting and display setting do i need to change any settings or leave it all on default and the whitelist do i enable all in it or just leave alone thank you(2019-12-09, 14:28)turbotec Wrote: [ -> ]do i change anything
2020-05-21, 18:41
(2020-04-13, 10:01)turbotec Wrote: [ -> ]I've never done any customization outside of making sure the audio output is right, as well as a few other cosmetic things like disabling the screen saver and such, configuring pvr addon, and weather. Kodi handles my media just fine. Generally I find that if I don't know what a setting does, I probably don't need to mess with it. Different strokes for different folks. Watch it for awhile, see what it does. If it's working fine to you that is all that matters.(2020-04-11, 14:25)Klojum Wrote: [ -> ]i was lookin some info on the player setting and display setting do i need to change any settings or leave it all on default and the whitelist do i enable all in it or just leave alone thank you(2019-12-09, 14:28)turbotec Wrote: [ -> ]do i change anything
