Throws an error for me when trying to browse for a value for a 'path contains' rule for the music library.
cpp:
Error Type: <class 'NameError'>
Error Contents: name 'ltype' is not defined
File "/home/xbmc/build/kodi-19/kodi-build/portable_data/addons/plugin.library.node.editor/plugin.py", line 6, in <module>
addon.run(sys.argv)
File "/home/xbmc/build/kodi-19/kodi-build/portable_data/addons/plugin.library.node.editor/resources/lib/addon.py", line 848, in run
Main(params, ltype, RULE, ATTRIB, PATHRULE, ORDERBY)
File "/home/xbmc/build/kodi-19/kodi-build/portable_data/addons/plugin.library.node.editor/resources/lib/addon.py", line 232, in __init__
self.RULE.browse( self.PARAMS[ "actionPath" ], self.PARAMS[ "rule" ], self.PARAMS[ "match" ], self.PARAMS[ "content" ] )
File "/home/xbmc/build/kodi-19/kodi-build/portable_data/addons/plugin.library.node.editor/resources/lib/rules.py", line 936, in browse
returnVal = xbmcgui.Dialog().browse(0, self.niceMatchName( match ), ltype )
NameError: name 'ltype' is not defined
Guess that should be
self.ltype
Also, line 956 in rules.py throws an error because of the attempt to decode to utf8. I added
and not PY3
to the if statement but that's probably not the best way to do it.
Anyway, those are the only errors I've run into so far.
get an error when add more then one rule
Thanks for testing, both issues should be fixed. I still want to take a look into other two possible issues and will likely submit to the official repository next week.
