Full Version: adding menu item
I want to add a menu item in the main menu.
Uner Movie i want i new menu item xmas with his own library.
Is there a way to do it without programmering/editing xml files?
Because i don't understand it.
Kind Regards,
Bianca
Bianca, it is possible.
Is the source of these Christmas movies isolated. ie. Are Christmas movies in a folder by themselves. If not how can you identify them separately from the other movies?
(2019-12-16, 18:46)dudok Wrote: [ -> ]Hi,
Kind Regards,
Bianca
the only way is to use favourites
you can set it up in  Categories  plugin.library.node.editor
1 library.node.editor
new video library
movies
*new node
chtistmas
2 add content
add rule
click on title pick plot
plot contains christmas
3add rule
plot contains santa
match any
(2019-12-16, 19:28)LongMan Wrote: [ -> ]Bianca, it is possible.
Yes the movies are in a seperate folder.
(2019-12-17, 01:58)the_other_guy Wrote: [ -> ]
Kind Regards,
Bianca
new video library
movies
*new node
chtistmas
2 add content
add rule
3add rule
plot contains santa
match any
oke thanks for the tiip i will try that. But then if a want to add a new item them i'm stuck ?
the tip to use favourites works. However some of the movies doesn't have plot as santa nor christmas. How can i add a extra genre type to a movie?
add rule
title
browse for value
add rule
click on title pick path
add <no value> eg.(D:\TELEVISION)
<no value>    drive letter seperate folder
i think you understand me wrong. Because one of the movies has movie information komedie/romance. I want to add christmas to the movie info.
If you have them in a separate folder eg "Christmas Movies".
Follow the other guy instructions but use the rule "path contains Christmas Movies".
That should do the trick.
You can create a playlist or a Video Node and use it with you favorite skin (if it supports it.)
Hope that helps.
Cheers,
LongMan
thanks i got it and it works. Thx everybody
